Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 3/20/07, 8:22 AM
Nalliah Thayabharan Nalliah Thayabharan is offline
Please Note: Nalliah Thayabharan is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Only High Efficincy Furnaces
As per 2006 OBC 12.3.1.2: Natural gas and propane warm air furnaces are required to have a minimum AFUE of 90%. This requirement does not apply to boilers or water heaters used in combination potable water heating systems("Combo") systems.
Oil fired warm air furnaces do not have a minimum efficiency published, but they may change because Table 12.3.1.2 has a "place holder" for minimum oil fired furnace efficiency.
There is a Canada wide initiative by Natural Resources Canada to increase the minimum performance level to 90% AFUE effective on December 31, 2009. All gas-fired furnaces that have their manufacturing process completed on or after the specified date, and that are subject to the regulation, will be required to meet the stated efficiency level. Natural Resources Canada is proposing that the mandatory reporting of the furnace blower electrical consumption come into effect at the same time.
Nalliah Thayabharan
Expert Building Inspections Ltd
Markham ON
Old 3/20/07, 8:24 AM
George A. H. Luck's Avatar
George A. H. Luck George A. H. Luck is offline
Default Re: Only High Efficincy Furnaces - Effective Jan 01, 2010
This is likely to keep the furnace repair guys happy!
Old 3/20/07, 10:25 AM
lewens's Avatar
lewens lewens is offline
Send a message via AIM to lewens
Please Note: lewens is a non-member guest and is in no way affiliated with InterNACHI or its members.
The government should also make the manufacturers increase the life expectancy of condensing furnaces. As it stands the life of condensing furnaces is between 12 and 15 years. This, along with the increased cost of the furnace, does little to help in energy conservation. At present I believe the rating of 85% efficient is not considered high or it may be any thing up to 85%. I will take a non condensing furnace that will last me 20 to 25 years and forgo the additional 5 or 10% that I will get with a condensing furnace. The thought of installing a high efficiency furnace in an older home that is not adequately sealed up is a waste of money. In a new home, with all the new technology to seal the home, the installation of a Heat Recovery Ventalator is almost a must.
Larry
Old 3/20/07, 10:30 AM
Michael Larson's Avatar
Is anyone familiar with Ammana's lifetime heat exchanger warranty?
"The stainless steel heat exchanger and recuperative coil come with a lifetime limited replacement warranty. If either heat exchanger or recuperative coil should ever fail, the original owner will receive a new furnace."
http://www.sundanceenergy.com/dept.a...&l1=306&l2=320
Old 3/20/07, 10:43 AM
lewens's Avatar
The life time, I noticed on the site, is not stated. So,,,, the life of the furnace is????????>
Larry
Old 3/20/07, 10:49 AM
Larry
I found the brochure from Ammana here:http://www.amana-hac.com/Portals/1/pdf/CB-AMH95.pdf
Lifetime Unit Replacement
Limited Warranty
We’re so confident in the lasting power of your Amana®
brand 95% AFUE Two-Stage (Convertible) Furnace that
we protect it with the best warranty in the industry, a
Lifetime Unit Replacement Limited Warranty. If the heat
exchanger on this unit fails on the original, registered owner,
WE WILL SUPPLY A NEW UNIT FOR FREE.** All remaining
parts are covered by a 5-Year Limited Warranty.
For added security, consider Amana AsureSM Extended
Service Protection, which provides extended parts and labor
coverage for your entire heating and cooling system.
Old 3/20/07, 10:54 AM
Roy D. Cooke, Sr's Avatar
This is a great selling gimmick .
The average person in my area only lives in the home for 8 years so this is no good .
The other is for the original purchaser .
So to me it is not much value .
Roy Cooke
Old 3/20/07, 11:02 AM
Roy, how many "lifetime warrantys" are transferable?
Of course there is some limitation! There not going to warranty it for your kid's kids should they end up in the same house.
People have gotten too used to paying cheap prices.
Guess what. The quality of the product often suffers.
It's the same argument we use to convince our customers to buy our product.
Old 3/20/07, 11:05 AM
I feel A transferable warantee for 15 years is much more valuable .
Roy Cooke
Old 3/20/07, 11:10 AM
Roy Cooke
As do I. That will happen when people are willing to pay for it.
Old 3/21/07, 2:30 PM
phinsperger's Avatar
Larry
I have a used, but in excelent shape a 125,000 btu mid-eff Heil unit for sale.
Old 3/22/07, 9:44 PM
bjones1 bjones1 is offline
Send a message via MSN to bjones1
Please Note: bjones1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Paul, if you're serious, phone me please or email me.
High Efficiency venting????? Matt Lewis Inspecting HVAC Systems 8 11/9/07 11:31 PM
No high side Alan Dow Inspecting HVAC Systems 2 8/22/07 2:47 PM
High Radon Test Results gbrasseur Miscellaneous Discussion for Inspectors 11 9/19/06 8:49 AM
Newer Westinghouse furnaces jweinberg Inspecting HVAC Systems 2 7/7/06 12:49 AM
