Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 9/10/08, 5:22 PM
Default Ontario Building Code Question
This is from the 2006 OBC:
9.15.5.2. Support of Beams
(1)
Not less than a 190 mm depth of solid masonry shall be provided beneath beams supported on masonry.
(2)
Where the beam referred to in Sentence (1) is supported below the top of the foundation walls, the ends of such beams
shall be protected from the weather.
Am I reading this wrong - 190 mm (7.5 inches) seems excessive. In the 1997 code it was 3.5 inches of bearing.
7.5 inches would almost take you through some foundation walls.
Old 9/10/08, 6:20 PM
bjones5's Avatar
bjones5 bjones5 is offline
Send a message via MSN to bjones5
Default Re: Ontario Building Code Question
(1) Not less than a 190 mm depth of solid masonry shall be provided beneath beams supported on masonry.
(2)
(1) they want a full block under the beam in a block wall.....solid concrete under the beam in a poured wall.
(2) the ends are to be covered where (if) they jut past the outside of the foundation walls.
Brian Jones,
226-662-0152
mcbridesown@hotmail.com
To all newcomers,
"Ceade Mille Failte"
(Gaelic for "A Hundred Thousand Welcomes")
Old 9/10/08, 7:56 PM
[/left]
So where is the 3.5 inches of bearing now covered?
Old 9/11/08, 1:56 AM
Claude Lawrenson's Avatar
Claude Lawrenson Claude Lawrenson is offline
9.23.8.1. Bearing for Beams
(1)
Beams shall have even and level bearing and shall have not less than 89 mm length of bearing at end supports, except as required in notes to Tables A-8 to A-11.
Cheers, Claude Lawrenson NACHI03121515
Inspection Support Services Inc.
"Those who can do. Those who CARE, teach" or
“Teaching is the highest form of understanding.” Aristotle
Old 9/11/08, 10:20 AM
Thanks gents. That explains everything.
Article on Commercial and Residential Inspections and Assessment mcyr Commercial Inspections 2 8/6/07 2:26 AM
Ontario Adopts a New Fuel Oil Code effective March 1, 2007 Nalliah Thayabharan Canadian Inspectors 0 4/18/07 11:51 PM
