Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 3/2/09, 8:23 AM
dplummer dplummer is offline
Please Note: dplummer is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Ontario Plumbing Question
In Ontario are back flow proventers required in ALL new basement bathrooms? Thank You!
Doug
Old 3/2/09, 1:34 PM
Claude Lawrenson's Avatar
Claude Lawrenson Claude Lawrenson is offline
Post Re: Ontario Plumbing Question
7.4.6.4. Protection from Backflow
(1) Except as permitted in Sentence (2), a backwater valve that would prevent free circulation of air shall not be installed in a building drain or in a building sewer.
(2) A backwater valve may be installed in a building drain provided that,
(a) it is a "normally open" design conforming to,
(i) CAN/CSA-B70, "Cast Iron Soil Pipe, Fittings, and Means of Joining",
(ii) CAN/CSA-B181.1, "ABS Drain, Waste, and Vent Pipe and Pipe Fittings",
(iii) CAN/CSA-B 181.2, "PVC Drain, Waste, and Vent Pipe and Pipe Fittings", or
(iv) CAN/CSA-B182.1, "Plastic Drain and Sewer Pipe and Pipe Fittings", and
(b) it does not serve more than one dwelling unit.
(3) Except as provided in Sentences (4) and (5), where a building drain or a branch may be subject to backflow, a backwater valve shall be installed on every fixture drain connected to them when the fixture is located below the level of the adjoining street.
(4) Where more than one fixture is located on a storey and all are connected to the same branch, the backwater valve may be installed on the branch.
(5) A subsoil drainage pipe that drains into a sanitary drainage system that is subject to surcharge shall be connected in such a manner that sewage cannot back up into the subsoil drainage pipe.
Cheers, Claude Lawrenson NACHI03121515
Inspection Support Services Inc.
"Those who can do. Those who CARE, teach" or
“Teaching is the highest form of understanding.” Aristotle
Old 3/2/09, 3:24 PM
Default Re: Ontario Plumbing Question
Thank You!
Doug
CAHPI Ontario SW Ontario Meeting Group Bill Mullen Canadian Inspectors 11 9/23/07 7:14 PM
No "H" clips? jbreazeale Structural Inspections 7 5/17/07 3:28 PM
plumbing question bglickman Plumbing Inspections 10 10/9/06 1:02 AM
Installing water softerner into a PEX plumbing system calhockey Plumbing Inspections 6 3/26/06 2:03 AM
