Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 9/3/08, 10:46 AM
Bryce W. Jeffrey Bryce W. Jeffrey is offline
Default polyurethane insulation
Polyurethane spray foam insulation appears blue. I hope that is correct. If used in the basement does this application require a fire retardant barrier such as drywall or is it OK to leave it uncovered?
Help please as I am getting conflicting views.
Old 9/3/08, 12:03 PM
Claude Lawrenson's Avatar
Claude Lawrenson Claude Lawrenson is offline
Default Re: polyurethane insulation
A few references:
http://www.gni.ca/contractor/airbarrier.html
http://www.obc.mah.gov.on.ca/PageFactory.aspx?PageID=730
http://www.barrie.ca/docs/SFD%20Changes%202006%20Code.pdf
Cheers, Claude Lawrenson NACHI03121515
Inspection Support Services Inc.
"Those who can do. Those who CARE, teach" or
“Teaching is the highest form of understanding.” Aristotle
Old 9/3/08, 11:59 PM
Yuri Olhovsky's Avatar
Yuri Olhovsky Yuri Olhovsky is offline
Bryce, any type of foam, regardless of whether it is spray or rigid, is a fire hazard and should be covered if used inside the building envelope.
Yuri Olhovsky CMI, CEA, PHPI, RASDT
National Home Inspector NHICC #00372
Richmond Hill, ON Canada
NACHI ID 04070207
www.homeinspections4u.biz
Old 9/4/08, 9:42 AM
Except no protection required if used in crawlspace.
Old 9/4/08, 10:02 PM
Darren St.jacques's Avatar
Darren St.jacques Darren St.jacques is offline
Should it be covered if a gas furnace and water heater are present in the crawlspace?
Darren
Old 9/4/08, 11:29 PM
Darren
Nope
9.10.17.10. Protection of Foamed Plastics
(1)
Except as provided in Sentence (2), foamed plastics that form part of a wall or ceiling assembly in combustible
construction
shall be protected from adjacent space in the building other than adjacent concealed spaces within attic or roof
spaces
, crawl spaces, and wall assemblies,
Old 9/7/08, 7:57 AM
Rodney Misener's Avatar
Rodney Misener Rodney Misener is offline
Darren
Yes in Nova Scotia. NBC states it.
Rodney Misener, CMI
Trinity Inspection Services
Pictou County, Nova Scotia
http://www.trinityinspectionservices.com
Certified Master Inspector
Certified Level 1 Thermographer
Certified Energy Advisor
WETT eCertified Inspector
IAC2 Radon/Mold Certified
Infrared Certified
Old 9/7/08, 9:02 AM
Rudolf Reusse Rudolf Reusse is offline
Please Note: Rudolf Reusse is a non-member guest and is in no way affiliated with InterNACHI or its members.
Home inspectors are not obligated to determine whether or not an observed defect is in fact in violation with the applicable section of the Building Code. Nevertheless - if I find any exposed rigid or foam insulation which - in my opinion - might release toxic fumes when on fire - I always recommend corrective actions.
RUDOLF REUSSE - Home Inspector since 1976 - TORONTO
Old 9/7/08, 9:14 AM
Bill Mullen Bill Mullen is offline
Please Note: Bill Mullen is a non-member guest and is in no way affiliated with InterNACHI or its members.
That's what I do as well, Rudolph. However, I have been questioned sometimes when I pointed out that foam insulation in a cold storage room under a porch should be covered. I don't get all anal about it in that location, but present it as a suggestion. Should I be more insistent?
Bill Mullen
Old 9/7/08, 10:29 AM
Banned
Bill Mullen
Be more insistent on multiple interconnected line voltage smoke dectectors plus battery back-ups. I some times recommend up to 3-4 in the basement due to dryer, water heater, furnace/boiler, electrical panel being situated in different rooms with closed doors. It's cheap insurance for detecting a fire before it really gets developed.
IMHO, the foam issue is way overstated by the codes!! Seems it's just a historical artifact from when foam panels first came out. We have foam pillows/cushions, carpet pads, and lots of other plastics in houses today but we don't have to cover them with 1/2" drywall. Haven't heard of higher #'s of deaths related to insulation foam in fires!! It's the CO and cyanides from a variety of sources.
http://www.polyurethane.org/s_api/se...d=936&did=3671
From http://www.medscape.com/viewarticle/559849:
"In a study done in Sweden at the National Testing Center, they looked at a controlled burning of household items, everything from VCRs to furniture to chairs to cables, anything that you would find in a residential structure. What they found was amazing throughout. These are the isocyanide levels that came through all the building materials. But the biggest that came through is fiberglass insulation. The insulated wool actually threw off the highest levels. When you look at it from the fire service perspective, when you look at the pink and yellow insulation inside walls and you see firemen out in the streets, you know they are fighting fires and they are going through tearing the building apart to find any hot spots in it and you see the insulation consistently being pulled out and looked at.
This has become a significant concern in the fire service, because we used to concentrate on the wool, the cotton materials, and some of the plastics."
BTW, silk throws off cyanide also!!
From the Portland Concrete Association in an article about the fire resistance of ICF homes:
"Practically any organic material, like wood or plastic, gives off emissions when subjected to intense heat or flame. The Southwest Research Institute reviewed numerous existing studies of fire emissions and concluded that emissions from polystyrene foams are “no more toxic” than those of wood."
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 1:30 PM
History of Insulation with Masonry mcyr General Inspection Discussion 7 2/27/08 7:53 PM
Vaulted Ceiling Insulation rcooke Canadian Inspectors 4 1/22/07 12:24 PM
New Old Insulation rcooke Canadian Inspectors 1 12/13/06 5:25 PM
