| Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics. |
Well finally seen one in action, check it out at http://www.renewability.com/powerpipe.htm
Chuck Crooker I.M.M., Canadian Home Inspectorhttp://www.crookerhancox.com "Not just an inspection, an Education!!!"
I don't know much about these systems,but I can't imagine getting much heat from a drain pipe. I would guess that much of the effectiveness comes from the localized savings of energy that is apparent in the water heater. Do they have any information on whole house energy consumption with these in place?
My concern is that with much exposed copper surface area, the majority of the heating is coming from the cold water inside these lines absorbing heat from the conditioned space of the house and not so much from the drains. this would lead to an increase in the amount of energy consumed by the heating device of the home. Besides if one were going to install these wouldn't it be more effective to place the wraps around horizontal sections of pipe(where the heated water is in most direct contact with the inner pipe surface) rather than vertical sections (where a lot of the water is free falling through the lumen of the drain? JMHO Steve Radabaugh Preferred Property Inspections Columbus Ohio Home Inspection Ohio Home Tips Westerville, Ohio |
But the biggest concern is: how long it would take for an average homeowner to recuperate the cost of this gadget (~$1000) before any savings is achieved... Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
In a larger new home with 2-3 baths with showers, a lot of excellent drain design will have to be done to get all showers to drain to 1 waste stack or you buy an extra unit or 2. I see a lot of basements finished with a shower for bedrooms located there......how much will it cost to recover that heat? The best place for these are barracks, dorms, gyms and other commercial, institutional, industrial quick payback locations. If the price comes down with volume production and there are good subsidies (instead of giving oil companies tax breaks called "depletion allowances"; we drained the oil field ......poor us!), maybe it will become a decent home investment. Want to save $$$ on hot water, use less.....cold water washes, low flow showerheads, not having more than 1 shower per day (most times I only need a shower every 2-3 days; not that active on HI's). |
Below copied from: http://en.wikipedia.org/wiki/Drain_water_heat_recovery
Hot water heat recycling From Wikipedia, the free encyclopedia (Redirected from Drain water heat recovery) Jump to: navigation, search ![]() A typical unit in the basement of a family home. Hot water heat recycling (also known as drain water heat recovery, greywater heat recovery, or sometimes shower water heat recovery) is the use of heat exchanger technology to recover and reuse hot water heat from various activities such as dishwashing, clothes washing and especially showers. The technology is used to reduce primary energy consumption for domestic water heating while also reducing greenhouse gases. Standard units save up to 60% of the heat energy that is otherwise lost down the drain when using the shower. The technology is fully recognized in Canada where the federal ecoENERGY retrofit for homes program offers grants for installations and the EnerGuide for New Houses program has energy savings and energy credit calculations that it uses for new home construction. Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
gmortensen is a non-member guest and is in no way affiliated with InterNACHI or its members.
I've only seen them on new homes that were sold with the eco energy tag. They don't cost anything to run, so I don't see the issue with it.
sdavies is a non-member guest and is in no way affiliated with InterNACHI or its members.
If a client wants to install one they can have an energy audit done and recover some of the cost through the EcoEnergy Program..
Steven, CEA Certified Energy Auditor NRCAN Licensed. GO GREEN |
You might get more info by calling toll free: 1-877-606-5559
When you flush the toilet, water being discharge down the drain already used heat from the house to reach ambient temperature; this heat exchanger is recuperationg heat that is going down the drain to pre-heat water used to refill the toilet tank. That's if you install the heat exchanger as per manufacturer's recomendations that is to the whole house cold supply and not the WH supply only. It may even recuperate some of the body heat being flushed in the process Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
Over $1000 for the 4' dia. 5 ft. model.
Pricing Page I don't think I'll be installing one anytime soon. But I think all the those who insist on being "green" should be forced to buy one to save mother earth. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
Remember the flush is one large surge of water with the time of the flush not being fully coincident with the time of the fill........this is what is needed to recover some of this parisitic heat loss from the house.* In this situation, it isn't happening. * When working as energy analyst for the Gov here, I calculated that the parasitic heat loss just from toilet flushing in a family of 4 with electric heat was about $115/year. Figures I used were: water comes in at 48-50 deg F and leaves at 70F.; electricity was $0.083/kWh. This would be much better now as water saving tanks are not only saving water but a bit more energy also. Last edited by Brian A. MacNeish; 3/5/08 at 3:51 PM.. |
Brian,
So what you're saying is that this system will not produce a reasonable pay back on investment for residential application? Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 36 | 10/27/10 11:21 AM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 9:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 7:39 PM |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 72 | 3/12/08 12:19 AM |
| Emergency Lighting (commercial) | mcyr | Electrical Inspections | 24 | 6/10/06 11:06 AM |
