| Canadian Inspectors This forum is specifically for Canadian Home Inspectors. |
rcooke is a non-member guest and is in no way affiliated with InterNACHI or its members.
By Craig O’Brien In the residential real-estate market, many purchasers erroneously believe that when they obtain a pre-purchase home inspection for a few hundred dollars, they are purchasing an enforceable guarantee that the home is free of any and all defect. When a defect is discovered subsequent to purchase, the home inspector is sued in negligence and breach of contract, with the allegation that the home inspector should have uncovered the defect in the course of inspection. The success rate of claims against pre-purchase home inspectors remains relatively low, but the volume of claims is causing significant challenges to the home inspection industry. The deductible on insurance policies for home inspectors often equates to the gross income from ten home inspections and one unmeritorious claim can easily negate months of profit. From a purchaser’s perspective, the reasons for including the home inspector in a claim for home defects are self-evident. Vendors are liable for latent defects of which they were aware and did not disclose to the purchaser. The home inspector is liable for patent defects they failed to uncover during the course of inspection. The purchaser and their counsel rationalize that any defect uncovered after closing is either latent or patent. If latent, they deduce that the vendor should be responsible. If patent, the home inspector is negligent or breached the contract. Either way, innocent purchasers believe they will recover damages. Contrary to this belief, there is a significant gap between the latent defects known to the vendor and patent defects that the home inspector should have identified. Neither a vendor nor a home inspector is liable for a latent defect unknown to the vendor at the time of sale. Purchasers and their counsel often forget or ignore the fact that the gap between latent defects known to the vendor and patent defects apparent to the inspector remains the municipal address of caveat emptor. Home inspector negligence cases are invariably fact-driven, but the matter of Rayne v. Martin [2006] B.C.J. No. 2040 is an apt example of the many claims by purchasers for defects that fall within the caveat emptor category. The plaintiff purchased a mobile home and later discovered extensive water and structural damage that made it worthless. The vendor testified that she was unaware of the defects, and the defects were not uncovered during the course of inspection. The vendor’s evidence was accepted and the court found that furniture and a false ceiling hid the water damage. As a result, the vendor was not liable as she did not know of the defect and the home inspector was not liable as the damage was not readily apparent during a visual home inspection. The standard of care owed by a home inspector is that of a reasonably prudent home inspector, and these standards are codified in the standards of practice of the profession’s regulatory bodies, based on Canadian Association of Home and Property Inspectors standards. For instance, Brownjohn v. Ramsay [2003] B.C.J. No. 43, held that home inspectors are not required to be experts in pest infestation, and the inspector was not liable for failing to uncover signs of an active termite colony. The pre-purchase residential home inspection is a visual inspection of accessible systems intended to uncover patent defects such as water staining, cracks in foundations, or improper or inadequate insulation that may be indications of serious deficiencies. Home inspectors are specifically instructed not to undertake “destructive” or “invasive” inspections, as there is a risk that the inspection itself could cause property damage for which the inspector would be liable. In Li v. Baker Street Home Inspection Services Inc. [2005] O.J. No. 3846, the court held that a home inspector was not required to open an attic hatch that was painted shut; to do so would cause damage to the vendor’s premises. He was therefore not liable for failing to uncover cracking and splintering roof joists that were readily observable had the attic been accessed. In Martin and Brownjohn this meant that the home inspector was not required to move furniture, roof panels, cabinets or baseboards as part of an inspection. As a result of the increased number of suits against home inspectors, inspection reports now normally contain robust limitation of liability clauses, descriptions of the purpose and scope of the prepurchase home inspection, and lists of systems explicitly not covered by the home inspection. Too frequently home inspectors fail to insist that the purchaser read these portions of the agreement prior to the inspection, only to have a judge rule them unenforceable as a result. In Brownjohn, the exclusion clauses were rescinded because the inspector did not draw the purchaser’s attention to these clauses, whereas in Martin the home inspector ensured that the purchaser read the inspection agreement and was able to rely on its contents. Home inspectors should ensure that the purchaser reads the agreement prior to proceeding with the inspection. The standard form agreement of purchase and sale was intended to reduce the number of purchaser’s claims by limiting vendors’ liability for subsequently discovered defects to latent defects of which the vendor was aware and failed to notify the purchaser in the declarations portion of the form, and by stipulating that the form supercedes any oral warranties or guarantees. The form therefore provides purchasers the opportunity to obtain a home inspection to their satisfaction prior to purchasing a residential property. This is intended to allow the purchaser to satisfy him or herself of the residence’s condition prior to purchase and to obviate the need to rely on the vendor’s statements. The result has not been a reduction in claims but rather to add the home inspector to the list of defendants. Purchasers think of home inspection services as an insurance policy, but as often occurs with the insurance policy they don’t read the limitations and exclusions clauses until it’s too late. As in Martin, Brownjohn, Li and an a myriad of others, purchasers must be mindful that the principle of caveat emptor still has a role to play in residential real estate. Craig O’Brien is an associate with Nelligan O’Brien Payne in Ottawa and practices in the areas of insurance defence, personal injury and civil litigation. I N S U R A N C E Home inspectors found liable for defects if exclusionary clauses not read by buyer Craig O’Brien “Purchasers and their counsel often forget or ignore the fact that the gap between latent defects known to the vendor and patent defects apparent to the inspector remains the municipal address of caveat emptor.” Reproduced from the August 10, 2007 issue (p. 9) of The Lawyers Weekly with the permission of LexisNexis Canada Inc., 75 Clegg Road, Markham, Ontario, L6G 1A1 |
Thanks Roy thats a good one.
gmortensen is a non-member guest and is in no way affiliated with InterNACHI or its members.
A client I have is fighting an old home inspector for negligence. He has a limited liability clause in his contract, which the lawyers don't think will hold up, because the inspection was done without the client present and the contract was not available for viewing. I believe it was Roy or Ray that said to have your contract and SOP's on your website, so they can be viewed. I think that tip is money in the bank.
Oh yeah! Thanks Roy, that was a good article.
Glen
I have my contract on my website. I refer my clients to it when ever I can prior to the inspection. http://www.raymondwand.ca |
Here is another case with limitation of liability with some interesting claims and the finding of the court.
Insurance Newsletter, October 2003 Home Inspection The liability of home inspectors in connection with home inspections undertaken for purchasers of residential homes was recently considered in the decision of Mr. Justice Coo of the Superior Court of Justice in John DiSanto vs. Amerispec Home Inspection Service. I had the privilege of acting for the defendant in this action. In this action the plaintiff (purchaser) claimed that the defendant (home inspector) breached its contractual obligations in the way in which it conducted a home inspection. More specifically the plaintiff complained with respect to flaws and problems not seen, or at least not properly reported on, by the home inspector, despite the fact that they were all readily observable and accessible. The plaintiff argued that had there been a proper report, he would have not have purchased the home, as the cost of required repairs would have put the real cost out of his reach. Accordingly, the plaintiff claimed the cost of the repair work to remedy the unreported problems. Prior to conducting the inspection, the parties entered into a written inspection agreement which provided, among other things, that responsibility for observing and reporting on features or problems was limited to what could be seen. The defendant argued that the inspection agreement limited liability to the return of the contract price paid by the plaintiff. The limitation clause in the agreement provided as follows: "Limit of Liability–if we [the defendant], or our employees, inspectors, or any other person, you [the plaintiff], claim to be our agent, are careless or negligent in making the inspection and/or preparing the Report, our liability to you is limited to the fee paid for the inspection services and, any releases from any additional liability. There will be no recovery for secondary or consequential damages by any person. By signing this agreement, you agree to this limitation on our liability."Additionally, in bold, centered and capitalized type, on the second line of the agreement the following words appeared: THIS AGREEMENT LIMITS OUR LIABILITY - PLEASE READ IT.The plaintiff argued that he did not read the agreement and therefore was not bound by its terms. The court did not accept this argument and found that there was nothing to prevent the plaintiff from taking whatever time he might have required to read the agreement before signing. The court found that there was "nothing done by the inspector to inhibit that reading or to pressure the plaintiff." Moreover the court found that the inspection obligations or limits on liability were in language that was readily understandable and in print that was readable. As such the agreement was not in a form that was in some way unfairly drafted or printed. The plaintiff also argued that by the time the plaintiff arrived at the home site for the inspection, there was already an agreement between the parties made through a telephone conversation between the plaintiff's real-estate agent and the home inspection service. The plaintiff therefore argued the agreement between the parties was an oral one and not governed by the terms of the written inspection agreement for which no further consideration was provided. The court did not accept this argument. Although the court did find certain aspects of the inspection may have been performed negligently, the limitation clause precluded a finding of liability in excess of the cost of the inspection. |
Nice, I wasn't sure how bullet proof those words could be. I guess the important thing to do is make sure your client is well aware of the contract and its contents.
It has been said that a contract should not be overly worded and in every day language, and ideally not lengthy. Important clauses such a limit of liability should be at the begining of the contract rather than the end. Such clauses are weighed by their position in the contract so I have been told.
I have done recently 3 inspections for lawyers and not one has read the contract they just signed it .
I asked two why they would sign with out reading and they both said Contract does not matter if you do a bad inspection they will be after my ***** . Not quite those words but close to it . All satisfied and pleased . I did not do different with them then any one else. ... Cookie |
Further insights from a lawyers pov. in cases against inspectors.
The report identifies a problem condition, but NOT its significance or meaning. The report understates the significance or meaning of a problem condition. The inspector verbally dilutes the significance or meaning of a problem condition identified in the report. The report fails to suggest that the client retain an expert to more fully evaluate a problem condition. The report fails to identify a limitation which prevents or hinders a more thorough inspection of an area. The inspector does not obtain a signed contract from the client. The inspector presents the contract for the first time immediately before the actual inspection. The contract DOES NOT contain a limit of liability provision. The contract does not identify what services are being offered and excluded. During a reinspection, the inspector makes some admissions of liability to the client or agent. |
Dale Duffy 602.402.5305 Inspect Arizona Companies, Inc. Phoenix Home Inspectors, Inc. Your Leaking House-- Your Leaking House Message Board InterNACHI 2007 U.S.A Member of the Year |
Comments like that from a lawyer must be hard to swallow Roy. I did a couple of inspections looking over Rob Parkers shoulder and I think that was a point he had mentioned, that do the same routine on every inspection and you'll be less likely to miss anything.
I read a lot on these forums from vetrans like yourselves and I may not always say so, but I appreciate all the info and I'm sure I speak for most of us newbies. |
What effect does Ontario's "48 hour cooling off period" as it applies to any signed contract of sale.
Remember that oft quoted warning - "A contract is only as 'good' as the lawyer defending it." or conversly " No contract is 'lawyer proof". |
George
I think that only applies to consumer goods, like cars, vacuums, et ceteras. |
Some Canadians make fun of us none stop calling us 30 minute inspectors and those NACHOs . This has gone on for a few years . I have to laugh they then come and join NACHI and try to sell us on the great new secret system they have and how it is going to help Canadian Home inspectors and it will only cost NACHI members $1,100;00. For $289;00 NACHI continues to grow and others continue to shrink. Thanks for the encouragement it helps to show others how well NACHI works . ... Cookie |
| Authorization to pay for inspection at closing WITH credit card guarantee. | gromicko | Misc. Discussion | 1 | 7/23/07 10:58 PM |
| Home Inspection / Interested in Purchase (posted by Maryann McLendon) | AskNACHI.org | AskNACHI.org Forum | 2 | 5/16/07 11:36 PM |
| Help teaching Buyers about the Offer to Purchase! | gliebig | Legislation, Licensing & Legal Issues | 5 | 4/30/07 12:24 PM |
| Use Home Inspection to get out of Purchase Agreement | Nalliah Thayabharan | General Inspection Discussion | 23 | 4/18/07 11:03 AM |
