Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 3/26/08, 8:45 AM
George A. H. Luck's Avatar
George A. H. Luck George A. H. Luck is offline
Default Radiant Ceiling Heat
I inspected a house yesterday that had radiant ceiling heat. That is the type where the wiring is embedded directly into the plaster. There was quite a bit of cracking in the plaster and I thought that I remembered that there was a safety issue with this type of heating ( possibility of fire?) The trade name "Chromalox" seems to have significance.
Does anyone have any information on this, or is this prolonged winter freezing my poor old brain?
</IMG>
Old 3/26/08, 9:00 AM
Joseph Hagarty,  CMI's Avatar
Default Re: Radiant Ceiling Heat
George,
I have inspected several homes that had Electric radiant resistance heat in the plaster or pamnels directly mounted to the ceiling. I have yet to see one that was actually functioning.
Of the homes that had electric radiant, all had discontinued its use due to inefficiencies or failure. Replacement was usually made with forced air so that AC could also be added.
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 3/26/08, 9:06 AM
Thanks Joe. Believe it or not but this system was still functioning! I thought that there was a safety issue with this heating system and that it's further installation had been officially terminated.
Old 3/26/08, 9:08 AM
Marcel Gratton's Avatar
</IMG>
Below copied (en Francais) from: http://consommateur.qc.ca/acqc/29.htm
Les produits visés par l'ordre de la RBQ
Les marques visées par l'ordre de débranchement de la RBQ:
  • Flexwatt
  • Thermaflex
aussi commercialisées sous les marques
  • FlexelSafe-T-Flex
    Safe-T-Heat
    Aztec Flexel
    Aztec Flexel Scotland
  • Thermo-flex Scotland
Notez que depuis le début des problèmes, la RBQ a imposé un moratoire sur toute nouvelle installation de pellicules de chauffage radiant, moratoire qui demeure en vigueur. Malgré ce moratoire, les pellicules de chauffage radiant de marque Eswa sont toujours considérées sécuritaires et ne sont pas visées par l'ordre de débranchement. Par ailleurs, d'autres systèmes de chauffage radiant demeurent sécuritaires et peuvent toujours être installés:
  • le gypse radiant (fils conducteurs à l'intérieur des panneaux de gypse)
  • les autres systèmes radiant, par exemple, les planchers radiants
Hope this helps,
On The Level Inspection
Gatineau, Québec
Old 3/26/08, 9:14 AM
I am not aware of any specific issues with regard to electric radiant.
Some good info with regard to radiant heating here....
http://www.radiantdesigninstitute.com/page59.html
Joseph P. Hagarty
Phone: 610-399-3675
Old 3/26/08, 9:29 AM
David P. Valley's Avatar
</IMG>
Sounds like a great opportunity for infrared imaging....
Old 3/26/08, 9:36 AM
Raymond E. Wand Raymond E. Wand is offline
Banned for Violating Forum Rules
Please Note: Raymond E. Wand is a non-member guest and is in no way affiliated with InterNACHI or its members.
http://www.ofm.gov.on.ca/ENGLISH/Pub...4/94-033at.asp Also do a Google search: "radiant heating panel reacall"
Old 3/26/08, 9:37 AM
Michael Larson's Avatar
Yes that wil give you a pretty picture and if I had one I'd use it but a simple infrared/laser thermometer works fine for ceiling electric heat.
Michael Larson
Hudson, WI
[/I]
Old 3/26/08, 9:46 AM
George You can also mist the area with a spritzer bottle. If the panel is functioning you will get a distinct drying pattern.
Old 3/26/08, 9:57 AM
Bill Mullen Bill Mullen is offline
Please Note: Bill Mullen is a non-member guest and is in no way affiliated with InterNACHI or its members.
............Provided the vendor doesn't object to you spritzing water on his/her ceiling.
The IR Camera is awesome for something like this. You can find gaps and totally non-functioning wires.
I've run across quite of few houses with ceiling radiant heat and as George witnessed, most ceilings were cracked........some badly. Plaster doesn't enjoy being expanded and contracted over and over and over......
Bill Mullen
</IMG>
Old 3/26/08, 10:10 AM
I haven't seen panels cause cracking, but have seen the heat cables which are imbedded in the plaster to cause cracking and in some cases ghosting.
briddle briddle is offline
Please Note: briddle is a non-member guest and is in no way affiliated with InterNACHI or its members.
If you do a search on Radiant heat, you will find many discussions about this topic.
Old 3/26/08, 10:25 AM
Banned
Here's the scoop on radiant heat in the Maritimes:
"Thermaray" gyproc panels (14 inches wide) with heating elements embedded had problems in the late 1980's with the heating elements (quite thin wires) in parallel. They would break iindividually over time losing more wattage. The best way to check how much is still in play is to remove the wall mounted thermostat and check circuit amperage with a clamp-on meter. From there you can ascertain the wattage still good and if it should be adequate to heat the room. No fires resulted form this brand.
"Flexwatt" : This and others mentioned by MGratton have beeen related to fires. Most of the product was sold in Quebec and British Columbia. I believe virtually none was sold in the Maritimes but I heard a story that some may have gotten into Northern New brunswick from Quebec....Never confirmed.
ESWA Heating Foils: Manufactured in Finland (I believe), these are flexible flat elements laminated into heavy plastic or mylar type product. They come rolled up and are designed to be rolled out/installed on the lower face of strapping at 16 OC. I installed a bit of this in the 1970's. Have never heard of any problems with it.
Cable covered by plaster: early form in some 50's-60's houses; not much around but never heard of any problems.
Old 3/26/08, 10:36 AM
Great way to heat, but radiant panels only heat that which is direct line of site. In other words if you are seated at a table your upper body would be heated but your legs and feet are not as they are in the shadow created by the table fwiw.
Old 3/26/08, 10:43 AM
Banned
Speaking of ghosting, as I sit here today for a while longer, I'm working on a litigation against an award winning architect and builder in which one wall of a commercial/residential building had to be steel studded due to being on/near property line. They didn't design a thermal break into the wall (with steel siding to boot) and now we have some 2 storey high walls showing ghosting. That's just one of the many problems- this building has probably the worst designed and installed HRV and bathroom fan systems I have ever seen. (been familiar with HRV's-installing and inspecting- since 1981.)
Back to work.....damm- been up since 5:30....still have a meeting with another arch at 1:30 and inspection at 3:00 and have to drive 45 miles to get there!!! Then back home to this report. Some days...........retirement looks good.
Radiant ceiling heat? bmargiotti Inspecting HVAC Systems 16 1/24/12 10:46 AM
Radiant Ceiling Heat hhull Interior Inspections 9 7/26/07 8:19 AM
Radiant Heat Transfer rmyers1 Structural Inspections 0 5/31/06 11:21 PM
