Go Back   InterNACHI Message Board > Geographically Specific Forums > Canadian Inspectors
Canadian Inspectors This forum is specifically for Canadian Home Inspectors.
Old 7/27/07, 11:08 PM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Default Radon Gas
Very interesting read about Radon Gas.
https://www03.cmhc-schl.gc.ca/b2c/b2.../pdf/61945.pdf
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
Old 7/27/07, 11:38 PM
dcook1's Avatar
dcook1 dcook1 is offline
Please Note: dcook1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Radon Gas
Have read it sir.
I have a tester that is great. I placed it in two houses in Creemore that showed high levels. After getting a source of fresh air into both houses. the picocuries dropped off the map.
I have found that unless it is a known problem area, that most radon can be controlled with good ventilation. If you have a vacummed house this will help pull the gas into a house. If it pressurized, this will help eliminate the possibility.
Old 7/28/07, 11:27 AM
David A. Andersen's Avatar
That is how we mitigate commercial buildings and schools.
1st thing we look for is a disconnected economizer damper. Many maintenance personal do not understand the economizer and cut the wires and prop the damper open or closed. Thus the negative building pressures.
What tester is that?
Old 7/28/07, 8:35 PM
With the damper propped open, the building should be slightly pressurized.
Why is it maintenance personel are rarely trained in the basic theory and operation of the building systems? Found a lot of this when I managed an IAQ and air balancing company from 1990-1992.
Old 7/28/07, 9:12 PM
rcooke rcooke is offline
Banned for Violating COE
Please Note: rcooke is a non-member guest and is in no way affiliated with InterNACHI or its members.
That is what NACHI is all about getting information out to the NACHI members and other home inspectors who come here to learn and help spred more ideas and information .
Please as a guest try and not show up the newer inspectors .
We all wish to learn and help all.
The industry is so fortunate to have the NACHI BB No other association gives so much to so many for no charge too.
..... Cookie
Old 7/30/07, 1:32 AM
dcook1's Avatar
David,
http://www.radonmonitor.com/
I leave it in a house two to three weeks and check on it when I am in the area. Leave it in a corner that is not disturbed.
I usually charge $200 - $250 to do the testing.
Old 7/30/07, 9:50 AM
Darren St.jacques's Avatar
Darren St.jacques Darren St.jacques is offline
In my experiences as a chief engineer for some bigger highrise hotels, I will agree with that statement to a point. Very often, it is a lack of funds in the budget that allow proper repairs to the air handlers, as well as inexperienced personnel. A building is required to have a minimum damper setting of 20% open for fresh make up air, regardless of temperatures. But with the push to conserve energy and provide better performance, the damper settings are over-rode to close them tighter, or disconnected because the actuators no longer work.
I'm not saying this is acceptable, just what sometimes happens.
Darren
info@nookncranny.ca
www.nookncranny.ca
"You only fail when you stop trying!"
Old 7/30/07, 11:08 PM
Has this become a requirement of codes in your area or just an accepted recommendation from ASHRAE 62, the air quality document? Mechanical designers use this document as their guideline for good practice but in codes I have not seen it made mandatory yet.
Final review of Newman's radon references! Caoimhín P. Connell Ancillary Services & Additional Topics 12 10/4/08 1:23 PM
Anti-radon modifications inspired by Rochester man's ordeal gromicko IAC2 Forum 2 5/22/07 4:33 PM
As promised - Review of Newman's second radon study Caoimhín P. Connell Ancillary Services & Additional Topics 2 1/26/07 9:05 PM
As promised - Review of Newman's first radon study Caoimhín P. Connell Ancillary Services & Additional Topics 7 1/24/07 1:21 PM
FL HI's who offer but don't perform radon testing should list cert #'s on website. gromicko Legislation, Licensing & Legal Issues 1 7/10/06 11:01 AM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
