Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 5/26/08, 5:14 PM
William Marston William Marston is offline
Default repair to asphalt singles
Good day:
Here is a quick question to the experts.
I have medium gray asphalt shingles that in one area have lost the gravel due to excessive water. The downspout from an upper roof section is draining right on the roof shingles. This has caused the shingles to appear black.
Is there any way to repair this or is replacement the only option?
Thank you in advance
Bill Marston
Old 5/26/08, 5:46 PM
bjones5's Avatar
bjones5 bjones5 is offline
Send a message via MSN to bjones5
Default Re: repair to asphalt singles
You can try to replace that one section, if at all possible. After that, extend the downspout down to the trough.
Brian Jones,
226-662-0152
mcbridesown@hotmail.com
To all newcomers,
"Ceade Mille Failte"
(Gaelic for "A Hundred Thousand Welcomes")
Old 5/26/08, 5:52 PM
Like Brian said, if the granules are missing the shingles need replacing and the water needs redirecting to prevent premature wear.
Larry Kage, CMI
231 929 3525
Old 5/26/08, 8:34 PM
Thanks.
I was hoping there would be a liquid coating that I could simply apply. The problem with replacing a 2 x 8 ft section is one of color match.
Bill Marston
Old 5/27/08, 12:19 AM
bjones5's Avatar
Originally Posted by wmarston
Thanks.
Bill Marston
How conspicuous is the area in question?
Brian Jones,
226-662-0152
To all newcomers,
Old 5/27/08, 8:31 AM
William R. DeVries, CMHI's Avatar
William R. DeVries, CMHI William R. DeVries, CMHI is offline
as long as the color is some what the same no one will really know the difference, and 200 dollars over 4000 is enough to make the color blend in quite well.
Bill give me a call 613 561 5327
ASNT Certified Level II Thermographer
Certified Mold Inspector (Pro-Lab)
Certified Mold Inspector IAC2
Certified Home Inspector INACHI 07040201
Commercial Property Inspection
Certified Master Home Inspector
2008 InterNACHI member of the year
Magnum Property Inspection
Inspect it before you buy it
613 813 2353 mobile
We use and recommend
Home Inspector Pro Software
HomeGauge Software
Old 5/27/08, 9:32 AM
David A. Andersen's Avatar
You will never match the color unless the roof is deteriorated and there is a lot of shingle gravel located in the gutter systems. Collect the gravel, spray the roof with asphalt and cover with the shingle granules. I have never done this in large areas but have done this in very small repair areas.
If the roof is not a solid color, this process will work either as far as color match.
Old 5/27/08, 10:03 AM
Thanks for this thought. I will try this on a small area and let you know how it worked out.
Good thoughts. Thanks to all
Old 5/27/08, 11:49 AM
dcook1's Avatar
dcook1 dcook1 is offline
Please Note: dcook1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Bill,
Usually repairs are always highly visible. Check http://techniseal.com/home.php?region_Id=2&langue_Id=1 to see if this may help. Then as Brian said, direct the downspout of the lower roof areas.
Just a quick peek between inspections.... after the first one I had to come home and take a shower. it were a lovely dump... I mean house.
Old 5/27/08, 8:51 PM
Thank you for this. I will purchase this product, apply it and let you know how it worked. I will take a before and after photo.
Appreciate your time.
regards
Bill Marston
San Francisco Appliance, Air Conditioning and Heating Repair Ron Casey General Inspection Discussion 0 5/11/08 1:48 PM
Phoenix Appliance, Air Conditioning, Heating and Repair Scott P. Corsley General Inspection Discussion 1 5/1/08 6:34 AM
Nice Report on AL Wire Terminations - Enjoy pabernathy Electrical Inspections 0 7/2/07 12:35 PM
