| Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics. |
pmassie is a non-member guest and is in no way affiliated with InterNACHI or its members.
Ok.....
saw this and i wasnt sure (told client to further evaluate the condition because i really didnt know the answer) the roof sheeting on the house seams a little thin looking at the edge of plywood where a ventilation duct was (see pic) i couldn't measure it because of the attic height (pitch was 14-12) tell me if this thickness ( i would say about 5/16..??) is ok....or can you put thinner sheeting on a roof if it's a big slop??????????????? |
| Need a home inspection in Quebec? Check out InterNACHI's listing of Quebec certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
What was the rafter spacing?
Its 3 ply, ply wood...used all the time on roofs! I dont see no issues
to add slope has nothiung todo with how thick your roof sheathing would be so you know...1/2" is the thinest you would install on a roof.
That is 3/8 in. plywood and is within building practices with trusses spaced 24 inches for house build in Québec. If it was waferboard, it would need to be 7/16 in. minimum. Slope does not matter. Cheers, Marcel Gratton, NACHI04011210, CMI On The Level Inspection Gatineau, Québec http://www.onthelevelinspection.com/ Last edited by mgratton; 6/6/10 at 10:41 PM.. |
thx all !! well ! i'll call my client
| ** New Roof in question! Need Advise! | Mitch Patel | Exterior Inspections | 15 | 8/14/09 7:53 PM |
| Flat roof question again! | thalpin | Thermal Imaging, Infrared Cameras & Energy Audits | 3 | 6/19/08 10:36 PM |
| Flat roof question | rchorey | Exterior Inspections | 24 | 12/18/07 6:26 PM |
| Flat roof question | rchorey | Exterior Inspections | 1 | 12/18/07 10:18 AM |
| Wood shake roof question | jclark1 | Exterior Inspections | 4 | 9/11/06 9:23 PM |
