| Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics. |
This is a good read hope you enjoy
Site Grading and Drainage to Achieve High-Performance Basements Construction Technology Update No. 69, June 2008 By M.C. Swinton and T.J. Kesik Proper site grading and foundation drainage strategies are required in order to prevent water damage to basements and their contents. This Update reviews current construction practices used for basements, discusses some of the key issues and deficiencies that lead to problems, and provides practical suggestions for improving drainage and construction. The causes of basement moisture problems are mainly external, but they can be addressed by providing diversion of water away from the building, drainage along the basement perimeter, protection of the foundation walls against moisture, as well as by effective and durable grading near the basement and over the entire lot. (see Figure 1). Well-considered design of foundations and their interface with surrounding soils, combined with effective site drainage, can eliminate most of the moisture problems found in basements. ![]() Figure 1. Key elements involved in providing moisture protection for basements Moisture in Basements Basement moisture problems can be caused by water penetration (leakage), dampness in the form of water and water vapour migrating from the soil through the basement enclosure, and sump pump failures and sewer backups; they can also be caused by internal sources (humidity and plumbing leaks). Leakage occurs when there is an accumulation of water outside a basement wall or floor that is adjacent to a crack or defect. Surface water that is not directed away from the building can enter the basement through unintentional openings (e.g., joint cracks) at or below grade. By providing adequate drainage around the perimeter of the basement, this situation can be avoided. Alternatively, the basement can be waterproofed to resist hydrostatic pressures and thus control leakage. A fluctuating water table that rises above the basement floor level may cause leakage unless the basement is waterproofed or the groundwater level around the basement is lowered (to below floor level) by the operation of a sump pump. Waterproofing: Treatment of the surface or structure to prevent the passage of water through the basement envelope under hydrostatic pressures. Dampproofing: Treatment of a surface or installation of a technology to resist the passage of moisture caused by differences in moisture content, vapour pressure and temperature across basement envelope components. Note: Most foundations in new Canadian houses feature footing drainage systems with complementary dampproofing elements in the wall. This approach normally precludes the need for waterproofing. The basement systems discussed in this Update use drained approaches, without waterproofing. Achieving complete basement protection requires that appropriate control measures be provided for each form of moisture. There are five major considerations: 1. Site grading and drainage provide the first line of defence against exterior water entering the basement. 2. Foundation drainage (weeping tile and/or a granular drainage layer), combined with effective drainage around the basement walls and appropriate moisture protection of the below-grade basement envelope surfaces, provide the second line of defence. 3. Incorporating special design details and building in redundancy or factors of safety are ways of addressing weak links in these two lines of defence. Preventing leaks at window wells and sump pump failures are two examples of this approach. 4. Selecting the proper materials is an integral part of achieving complete basement protection (see Construction Technology Update No. 70 Options in the Selection of Materials for Basement Construction for additional information). 5. Eliminating and/or controlling indoor sources of moisture is the final step in providing adequate moisture protection in basements. The first three of these considerations are discussed in the following sections. Site Grading and Drainage Improper grading of the lot can result in poor surface drainage, ponding or flooding around the basement wall, foundation settlement or other damage, and basement dampness and other undesirable effects. It is one of the main generators of customer complaints, call-backs, warranty repairs and legal proceedings following the completion and occupancy of a dwelling. The two most common types of lot grading are: Back to front. With this type of grading, the rear lot line is the high point. First of all an elevated apron must be created around the house. This allows the surface drainage to flow towards the back and then forward to the street at the edges of the property. Back-to-front grading is typical of properties on a hillside or mountainside. Split. With this type, the house is the high point and the lot is graded so that surface drainage flows forward to the street and backward toward the rear lot line, which is then generally drained by a swale and catch basin system (see Figure 2). This is the more common type and is typical of housing developments on relatively flat land. ![]() Figure 2. Spilt site-grading and drainage plan Most surface drainage problems occur along the side lot lines between two houses, especially where the houses are close together. In these areas, a well-defined swale between the houses should be formed, which allows surface water to be diverted from the house and directed to the swale and then forward or backward, depending on the type of lot-grading approach used. Downspouts from the roof should discharge at grade onto a splash pad at least 1 m (3 ft.) away from the building; they should not be directed toward adjacent property but rather toward swales established between the properties and within the property boundary. In addition, the following guidelines should be followed:
Site grading and drainage require careful planning, as this work will not be executed until the building is nearly completed. However, moisture-protection measures must be considered and addressed during the construction process. Foundation Drainage and Moisture Protection To deal with groundwater and surface water that have not been directed away from the building by site grading, certain measures must be taken to provide adequate foundation drainage and moisture protection. Foundation Drainage The most common approach to foundation drainage is illustrated in Figure 3(a). It uses weeping tile (pipe that is continuous and perforated, which can be either rigid or flexible) installed around the perimeter of the foundation wall footing and covered with a granular material (gravel) prior to backfilling. ![]() Figure 3(a). Best practice associated with foundation drainage design It is important to keep in mind that although Figure 3(a) depicts the most common best practice, this approach is nevertheless not intended to drain large quantities of water away from the footings. The following situations require some additional planning to promote effective footing drainage:
![]() Figure 3(b). Drainpipe type and configuration needed to achieve optimal flow
Even when all of these best practices are followed, great emphasis still needs to be put on keeping the water out of the foundation drainage system. Footing drainage is the weakest link in the system, and this needs to be recognized in the overall drainage plan. Moisture Protection The basement walls below grade are surrounded by soil containing moisture. By providing an adequate slope away from the building, as well as an impermeable cap, one can minimize the amount of water directed toward the below-grade basement walls though not eliminate it altogether. Two approaches are commonly used for moisture protection of the below-grade basement walls, as depicted in Figure 4. ![]() Figure 4. Two options for effective drainage of below-grade basement walls The first approach involves using a drainage membrane or exterior insulation to control water migration through cracks and pores of basement structures. The second approach uses free-draining granular backfill to drain bulk water and dampproofing to control migration through the pores of the concrete. Both approaches provide a vertical path (air space) that allows the water along the soil/wall interface to drain, and both are backed up by a second water-resistant surface (i.e., dampproofing membrane or coating) that drains any water down to the footing. Each of these approaches has advantages. For example, in many parts of Canada, granular backfill materials are readily available and inexpensive. However, drainage membranes can also be used in unfavourable ground and weather conditions, without incurring the cost of removing excavated soil from the site. Both approaches provide effective perimeter basement wall drainage. Regardless of the approach taken, once the basement moisture-protection system has been installed, attention must be paid to the grading and capping of the apron (see Figure 2 in "Site Grading" section) surrounding the building to ensure that water is directed away from the grade/basement wall interface. Grading and capping of the perimeter drainage system ensures that this system does not become overloaded such that its carrying capacity is exceeded (see Figure 5). ![]() Figure 5. Two ways of providing effective grading and capping of the basement perimeter walls There are different ways of capping: one option involves using a low-permeability, fine-grained cohesive soil such as clay. Another more effective capping technique uses a membrane or low-permeability insulation board placed just below ground and sloped away from the wall. In all cases, the slope must be maintained after soil settlement and the capping must extend beyond the line of excavation and backfill. Grading and capping are the final steps in completing the foundation drainage system, tying it into the site grading and drainage system to control surface water. Special Design and Construction Measures There are numerous situations encountered in the construction of basements where special methods, materials or equipment may be required. Such measures include window wells and sump pumps. Window Wells Window wells are not a preferred basement construction practice, as they are lower than grade, attract snow and surface water, and can quickly overload the drainpipe system below. They rely on positive drainage from the granular layer below the window through a drainpipe to the footings. This helps avoid moisture problems at the foundation wall in the vicinity of the well and the wetting of the window itself. Figure 6 provides details for achieving proper window well performance. ![]() Figure 6. Critical considerations in the design and construction of window wells The performance of the window well can be improved by providing sufficient distance from the top of the granular layer to the bottom of the window opening to avoid accumulation of water and melting snow that could rise above the bottom of the window opening. Because the window is not designed to resist the build-up of water, this additional vertical space provides a measure of added protection. Sump Pumps Under some conditions sump pumps must be installed; for example, when there is a fluctuating water table or when the foundation drainage system is lower than a drainage receptor, making gravity drainage of the foundation impossible. Sumps and sump pumps should conform to building code requirements; however, several issues not explicitly addressed by code requirements should be carefully considered (see Figure 7): ![]() Figure 7. Important factors for sizing and locating sumps and sump pumps Area and configuration of the basement . For very large basements, or basements with unusual shapes (e.g., L-shaped, J-shaped or U-shaped), more than one sump may be required to achieve effective drainage. Low-permeability soils . The minimum required depth of the sump (750 mm or 30 in.) may not result in a sufficient water flow rate to the sump to maintain water levels at the extremities of the basement below the basement slab or floor assembly; this minimum may need to be exceeded to achieve an adequate flow rate. Basements used as living spaces . It is advisable to provide an emergency back-up power supply to the sump pump in case extreme weather causes a power failure. A pump alarm is also recommended to indicate pump failure and/or the need for maintenance. Review local practices for sump pumps for guidance on these issues. Summary The site grading and foundation drainage practices highlighted in this Update and summarized below can eliminate most basement performance problems in Canadian housing:
Performance Guidelines for Basement Envelope Systems and Materials The Guidelines were developed under the guidance of the project steering committee, which was comprised of industry association and government agency representatives. This committee ensured that the Guidelines reflect the best collective knowledge of Canadian industry and related public and private agencies. The complete report is now available at http://irc.nrc-cnrc.gc.ca/pubs/rr/rr199/index_e.html Further Reading Source and On-Site Controls for Municipal Drainage Systems. InfraGuide, Innovations and Best Practices: Storm and Wastewater (No. 3). National Guide to Sustainable Municipal Infrastructure. Ottawa, 2003. http://sustainablecommunities.fcm.ca/Infraguide/ National Housing Code of Canada 1998 and Illustrated Guide. Canadian Commission on Building and Fire Codes, National Research Council Canada. Ottawa, 1998. Performance Guidelines for Basement Envelope Systems and Materials: Final Research Report, Institute for Research in Construction, National Research Council. Ottawa, 2005. National Building Code of Canada. Canadian Commission on Building and Fire Codes, National Research Council Canada. Ottawa, 2005. M.C. Swinton is a Principal Research Officer in the Building Envelope program at the National Research Council Institute for Research in Construction. T.J. Kesik is a professor of building science in the Faculty of Architecture, Landscape and Design at the University of Toronto. © 2008 National Research Council of Canada June 2008 ISSN 1206-1220 ASNT Certified Level II Thermographer Certified Mold Inspector (Pro-Lab) Certified Mold Inspector IAC2 Certified Home Inspector INACHI 07040201 Commercial Property Inspection Certified Master Home Inspector 2008 InterNACHI member of the year Magnum Property Inspection Inspect it before you buy it 613 813 2353 mobile We use and recommend Home Inspector Pro Software HomeGauge Software |
OMG, are you sure?
Could you elaborate further? ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
Good info Billy!
'Imagination is more important than knowledge' (sometimes) Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007 www.360degreeshomeinspections.com Tel.# 416-722-6132 e-mail torontohomeinspector@yahoo.com |
john bubber is a non-member guest and is in no way affiliated with InterNACHI or its members.
A least we`re on the outside....thank God fer that.
Proper grading or not, exterior walls still should be waterproofed, not damproofed....sheesh. Grading will not solve most leaky basements, contrary to popular belief. -Figure 4. Two options for effective drainage .....they say a membrane can be used/effective....instead of,incurring the cost of removing excavated soil. As Lee Corso says, "Not so fast my friend". WHY LEAVE clay soil against the basement walls? This IS part of the problem. Don`t believe me, fine! Read what others know/say.... 6th paragraph http://www.dwightyoderbuilders.com/concrete.cfm http://www.bobvila.com/HowTo_Library...ion-A2095.html 4th para... The water pressure against a basement when the SOIL is thoroughly soaked is called hydrostatic pressure. It can force mosture through pores in the basement wall and even CRACK or Buckle the wall itself. 'Proper drainage'....does not equal raising/sloping the grade because grading doesn`t remove the clay and roots against the wall. A membrane placed x-inches below a raised grade is NOT going to keep all water out of the soil underneath the membrane, the soil will still become saturated on heavy-longer rains or spring thaws.Get rid of the dumbchtt clay soil! Scroll to Basement Walls http://www.fairfaxcounty.gov/DPWES/p...rineclay.htm#2 ....REMOVE and replace clay with sandy or gravelly soil. Sheesh. http://www.lrb.usace.army.mil/Amhers...st-2005-01.pdf 3.4.5 BACKFILL "Lateral pressure problems are exasperated by using UNSUITABLE Backfill, usually from ON-SITE excavations...." 3.2 Four sources likely contributed....... 1. Soil weight 2. Soil swell 3. Hydrostatic pressure 4. Pressure from frost Quit backfilling with clay soil against basement walls, walls that were not built to withstand these exterior pressures. Clay + bricks + blocks + wood + large stones/boulders etc, backfilled against basement walls instead of being hauled away. Talking about residential homes here, not skyscrapers `n crap where they use reinforcing rod etc and there are many good brains designing/planning, instead of a builder, big difference. And 'capping'? Placing 1' of CLAY against top of basement walls? This can/could CAUSE problems, especially if there is no 'top-wall support'. That 1' of clay can`t freeze-thaw??? Come on. Amherst link.... 3.4.11.1 ...'granular backfills can reduce lateral pressure.......TOP-WALL support is CRITICAL' http://www.lrb.usace.army.mil/missio...ex.html#Photos Raising and sloping the grade and/or french drains will solve this kinda stuff? http://www2.snapfish.com/thumbnailsh...6/t_=122238283 Poured walls, were DAMPROOFED when built and if ya eyeball pic`s 19,20 you`ll see grade is/was raised `n sloped away....it did NOT matter. Water can move/percolate through soil sideways, horizontally. All the rain that drops outta the sky around the house doesn`t all magically go towards the neighbors house or out to street. Last edited by john bubber; 8/2/08 at 1:55 PM.. |
I will not even read another reply from the guy as he is a waste of time.
| Options in selecting materials for basement construction | wdevries | Canadian Inspectors | 2 | 8/4/08 1:30 PM |
| Site Drainage Question | cbell1 | Exterior Inspections | 6 | 9/5/07 1:52 AM |
| A sinking Home | rcooke | Miscellaneous Discussion for Inspectors | 0 | 8/12/07 7:28 AM |
| Drainage & Grading | dmacy | Structural Inspections | 10 | 2/15/06 7:18 AM |
