Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 5/3/10, 7:48 PM
Michel Wilson Michel Wilson is offline
Default Slab on Grade in QC
Found my first slab in 500 inspections today. House is 30 yrs old, no movement/ heave or problems noted. But slabs up here need stem walls to footings below frost line to prevent heave (apart from new fangled insulated types i've read up on) So what do i write up?? "Dig down where accessible to determine if proper depth stem wall is installed... blah blah ??
Need a home inspection in British Columbia? Check out InterNACHI's listing of British Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/3/10, 8:32 PM
Roy D. Cooke, Sr's Avatar
Default Re: Slab on Grade in QC
I do only Visual inspections .
Write Foundation not visible..
No evidence of movement.
I would move on and do rest of inspection .
If you have any concerns then write further evaluation by qualified person.
Old 5/3/10, 8:41 PM
Good advice Roy.
And just for chits and giggles, This was my first home in 1972 built on a slab in Northern Maine equivalent to QC weather.
Never moved. Enough heat loss through the concrete and was known back then as a floating slab. Plus it was partially on ledge.
Old 5/3/10, 9:11 PM
Thks for advice boys...
Just that the client was very skeptical,
He understood slab meant no foundation..
and it is hard to convince him a slab was a foundation
and acceptable... but not used in this climate!!!
So why is this one acceptable, he asks !!!
writing "not visible" is easy, explaining is kinda difficult
Old 5/8/10, 2:42 PM
Vern Mitchinson's Avatar
Vern Mitchinson Vern Mitchinson is offline
Forgive my ignorance but what is a stem wall?
Vern Mitchinson_CCHI_CMI
Registar
AlbertaNACHI
International Association of Certified Home Inspectors of Canada
Old 5/8/10, 2:57 PM
Probably not too many in your area Vern, nor mine.
Per Bob Villa;
A stem wall is typically three courses high. Every set number of inches—which varies depending on code and the height of the wall—the cell or block is fitted with number five steel rebar to reinforce it once the concrete is poured. Once the three-course wall is in place, dirt is backfilled against the stem wall and compacted. This pad will be the base for the [COLOR=blue !important][COLOR=blue !important]concrete
[/COLOR]
slab.
Stem walls are supporting structures that are utilized as a means of joining the foundation of a building with the vertical walls constructed on the foundation. The wall is often constructed with the use of concrete and steel, and works with the foundational slab to create a solid basis for the building. Along with establishing foundational integrity for the building, the stem wall also aids in minimizing damage to the materials used to create the vertical walls.
[/COLOR]
Old 5/12/10, 4:07 PM
Thanks Marcel
Your right I have not seem anything like you describe. All foundations here have to be below the frost line 4'-6" or a grade beam on 12" dia X12' deep piles.
Registar
AlbertaNACHI
Old 5/17/10, 3:36 PM
Eric Lucko's Avatar
Eric Lucko Eric Lucko is offline
HI all,
New here, so bear with me as I get my "footing."
The Ontario Building Code, and most throughout Canada require footings that go below the frost level so foundations don't heave. In Ontario, it's 4'.
However, it's becoming more common in some single storey buildings that a "club" footing is used in lieu. Basically, if you get an engineer to stamp the design, you can pour a club footing in lieu of digging down 4' and pouring a strip footing, foundation wall, backfilling, etc. It is very cost beneficial in most cases, and will also give the same protection as long as properly insulated where required. Essentially, it is a slab thickening along the perimeter of the slab on grade. The cost of a Professional Engineer to design it is easily offset with all the additional excavations/backfilling, and concrete supply/formwork.
Old 5/17/10, 8:55 PM
Banned
Originally Posted by elucko View Post
HI all,
From what I hear, this footing has been used and is accepted by codes in Scandanavia for years.......but codes here still require an engineer to design/stamp one although they are well proven!!
One of the contractor's I served/advised for R2000 purposes in 1987-9 built 57 townhouses/duplexes in a project called "The Village" using this form of slab-on-grade foundation. He used a plywood/foam sandwich as the forms for the edges. There also was a 2' wide foamboard insulation skirt with a slight downward angle out from the foundation edge.
The plywood "forms" were left in place and backfilled against; it protected the slab edge insulation from UV light and mechanical damage.........foundation, insulation and protection......all in 1 step. He was named Canada's "R2000 Builder of the Year" for 1989.
Old 5/17/10, 9:16 PM
Timothy J. Smith Timothy J. Smith is offline
I agree with Roy, but i would also poke my head out the window and take a look around the house, i know it my neck of the woods there is a lot of "bed Rock" it's not uncommon to see slab on grad foundations.
TJ Smith
Serving Brockville, Ontario and Surrounding Area
TJ@AllOutHomeInspection.com
http://www.allouthomeinspection.com
"Inspecting your Future"
Old 5/17/10, 11:04 PM
Marcel Gratton's Avatar
If under slab ducts are present, I would mention in report that mould could be present in ducts and to have inspected / cleaned by a professional prior to purchase...
Cheers,
On The Level Inspection
Gatineau, Québec
Slab on grade possible failure question rbennett Structural Inspections 8 3/5/09 8:54 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
