Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 2/19/08, 4:22 PM
Roy D. Cooke, Sr's Avatar
Default Truss Uplift
Using trusses to support roof systems can result in problems
by Lucas J. Hamilton Editor's note: Following are the author's opinions about various building design issues. Views expressed are not necessarily those of Professional Roofing or NRCA.
During this time of mass residential construction, many homes are being designed and built with trusses as the primary means of roof support instead of traditional dimensional framing lumber supports. Materials used to make trusses are more cost-effective and easier to obtain in large amounts than traditional rafter and joist lumber, but this shift to more frequent use of trusses as roof supports has brought with it some detrimental side effects.
For example, a growing number of home builders have reported complaints from homeowners about cracks occurring in the drywall at the tops of interior walls on homes' uppermost levels. The most severe cracks typically occur near the centers of attic trusses. Building and design professionals have concluded these cracks are caused by a condition called "truss uplift."
Truss uplift involves significant differential movement that ultimately causes cracks to open in drywall. This occurs when one portion of a truss expands more than the rest, forcing the truss to lift upward at its center and cause a separation between the truss and interior wall.
Truss uplift occurs when a truss's top chords expand because of exposure to moisture. As the top chords expand, internal tensile stress occurs in the truss's web members, which pulls up the bottom chords (and the attached ceiling drywall).
Although truss uplift typically is more of a cosmetic problem than a structural problem, it can lead to increased energy consumption for cooling and heating buildings and be a source of excess moisture intrusion into attic spaces.
Unfortunately, there currently are few ways to completely eliminate truss uplift; however, employing proper moisture-management techniques can significantly lessen its effects. Although these techniques are beyond the scope of work typically performed by roofing contractors, you should find the information useful.
Why use trusses?
Trusses are prefabricated structural assemblies designed to support a home's roof system and top floor ceilings. They consist of dimensional lumber fastened together with gusset plates resulting in triangular-shaped openings/spaces. The outside members of a truss are called "chords," and the inner members are referred to as "webs."
The shift from site-built rafters to prefabricated trusses has become increasingly necessary because of the housing growth the U.S. has experienced during the past 10 years, and ease of installation is a factor. Rafters and joists typically are made from 2- by 12-foot boards, which often become scarce during housing booms. Many 2- by 12-foot boards currently available are cut from lower-quality lumber and prone to warping.
Manufacturers can use better-quality, smaller-dimension boards, such as 2x4s, which are more affordable and available but still provide the required structural strength when assembled into trusses. Although these qualities make trusses a practical method for providing structural roof support, truss uplift and the resulting drywall cracks present some challenges.
Causes and effects
Truss uplift is caused by wood's natural response to moisture exposure. This response occurs when humidity changes differentially in two areas (an attic floor and attic ceiling, for example). A truss's top chords expand as their moisture content increases.
Problems resulting from truss uplift are most common with flat-bottomed trusses in homes during winter when a truss's bottom chords, often covered by insulation, are kept warm and dry while its top chords are exposed to moisture from condensation. During winter months, warm, humid air emanates from buildings' interior use and occupants. The uplift movement occurs because, as the truss's upper components resize themselves under the differential moisture conditions, internal tensile stress occurs in the truss's web members, which then pulls up the bottom chords (and the attached ceiling drywall), resulting in a separation along the wall-to-ceiling juncture of the drywall.
To put this into perspective, consider a truss with top chords made of two members, each measuring 30 feet in length. The total movement anticipated from winter swelling caused by the truss's moisture content increasing is a 0.72-inch expansion per side, or a 1-inch total rise of ridge above the bottom chords. And once a crack forms inside a home, additional moisture generated by occupants and their activities can escape into the attic, travel to the cold attic ceiling surface, condense on the truss's top chords and cause further truss uplift.
The following factors can affect relative humidity in attics and should be considered when installing trusses as a roof system's primary means of support:
  1. Inadequate water vapor control at an attic floor—Increasing the amount of attic insulation without considering how the increase could affect roof surface temperature and a need for increased moisture control can result in higher moisture content in an attic. If extra insulation is added to an attic floor, the roof deck will tend to be cooler, often leading to condensation on the underside of the roof deck and upper truss chords. This moisture can increase the expansion of the top truss chords and eventually cause truss uplift. Unvented attics are a means of moisture management. In an unvented attic, a vapor retarder or a vapor-resistant insulation must be used. The International Building Code does not require vapor retarders to be installed in attic floors when roof systems are ventilated and, as a result, they rarely are employed in this area. When high levels of attic insulation are used, it is mandatory that you include a vapor-control strategy on the warm-in-winter side of the thermal envelope.
  2. Ventilation—Sufficient airflow on a roof deck's underside can help moderate the moisture content of an upper truss member. The airflow can facilitate removal of excess moisture before it has a chance to be absorbed by the wood truss members, thus reducing—though not eliminating—the effects of truss uplift. (Keep in mind, even properly ventilated roof systems can experience dramatically reduced airflow at night or when wind stops blowing. Heat from sunlight and air-pressure from wind are large driving forces, and when they are removed, airflow is reduced, allowing relative humidity to increase.)
  3. Night sky radiation—A roof system absorbs solar radiation during the day and emits radiation back into the sky at night. Different colors and compositions of roofing materials absorb solar radiation differently. As a result, different roof systems experience different roof surface temperatures and temperature swings/changes. If a roof system does not heat up during the day because of its light color and still emits radiation into the sky at night, its average temperature will be lower than that of a roof system that reaches higher temperatures during the day. On cloudless nights, it is possible for a roof system's temperature to drop several degrees below the ambient temperature. Lower roof surface temperatures can lead to lower temperatures on a deck's underside, higher relative humidity, and increased chance of moisture accumulation in the deck and top truss members. Also, higher-reflectance roofs can have lower temperatures during the day, which means less moisture drive out of decks/top chords of trusses. As more roofing products with high solar reflectances become available, increased emphasis on proper building science principles is vital.
  4. Closed-cell spray polyurethane foam (SPF) insulation—Insulating a roof deck's underside with closed-cell SPF insulation is another way to diminish truss uplift and other moisture problems in an attic. Previously used to create vapor seals on the exteriors of low-slope roof membranes, SPF insulation comes in liquid form and contains polyurethane and a foaming agent. It is sprayed through a nozzle into an attic wall, ceiling and floor cavities, where it expands to fill gaps and encapsulate trusses. Once expanded, this high-density foam insulation (2 pounds per square foot) provides thermal control and acts as a vapor and air retarder. However, installing SPF insulation in an attic can be five to eight times more expensive than installing fiberglass insulation.
Minimizing the effects
Although truss uplift is a powerful force, there are a number of ways you can min­imize its negative effects.
For many years, home builders have coped with truss uplift and the resulting separation between wall and ceiling gypsum boards by fastening ceiling gypsum boards at least 16 inches from interior partitions. Another popular method is to fasten crown molding to the ceiling and allow it to move up and down with the truss-induced movement, thus covering the gap formed at the top of the wall. Gaps tend to fluctuate in size, getting smaller in summer and larger in winter.
The best approach, however, is to minimize and stabilize attic moisture levels. This can be done, in large part, by installing a layer of thermal fiberglass batt insulation on the attic floor with a continuous vapor retarder facing the insulation's underside. By including a variable permeance moisture-control layer on the insulation's underside, excess moisture can be controlled, thus reducing the ultimate moisture content developed on a roof deck's underside.
Additionally, humidity-controlled fans can work well, and unvented attics will solve the problem.
Planning ahead
Although truss uplift can pose some hassles, trusses likely will remain the preferred roof support method for the foreseeable future. Truss uplift can be accommodated or eliminated if home designers and builders plan ahead and implement measures during construction to minimize its effects. An attic with an effective moisture-management system is a good start.
Lucas J. Hamilton is manager of building science applications for Valley Forge, Pa.-based CertainTeed Corp.'s Insulation Group.
Old 2/19/08, 4:25 PM
Michael Larson's Avatar
Default Re: Truss Uplift
Back In The Saddle Again
Roy sings
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
Never underestimate the difficulty of changing false beliefs by facts.
- Henry Rosovsky-Harvard
Michael Larson
Hudson, WI
InspectraPro
and
Minnesota Home Inspector
Old 2/19/08, 9:02 PM
Banned
Poor them!!!!! I went through the article quickly and it definitely needs some editing for building science principles/corrections. maybe later tonight.
Old 2/26/08, 2:37 PM
Russell Buchanan's Avatar
Russell Buchanan Russell Buchanan is offline
My house had this problem when I purchased it in 1998. Sometimes 1/4 inch cracks would appear where the wall meets the ceiling and mainly 1/8" cracks in every room. It would raise up and show the crack in winter and virtually hide itself completely in the summer. People had tried to caulk this evidently in winter, so when summer came and the ceiling lowered itself the caulk would look terrible.
i researched and asked several inspectors and no one knew how to fix it. I was able to fit it though and i did this by using Tuff-tape (sheetrock tape that you cant tear with your fingers) and Durabond 90.
Its been 10 years and it has held everywhere.
hope this helps.
Russell Buchanan
HomeGauge President
Special $645 (Regularly $845)
HomeGauge Droid* and the new HG Version 5
due out February 15th!
HomeGauge in the past has always been neutral with all orgs...but there's no denying it, INACHI clearly provides the best value to its inspectors and is dominating ASHI, NAHI and the others in all areas when it comes to giving value to its customers. HomeGauge plans to offer a special only for INACHI inspectors...coming soon!
Old 2/26/08, 2:54 PM
Roy D. Cooke, #5 Roy D. Cooke, #5 is offline
Please Note: Roy D. Cooke, #5 is a non-member guest and is in no way affiliated with InterNACHI or its members.
hope this helps.
If a person has a truss uplift area .
The easiest fix I know of is to get trim and fasten it to the ceiling only and then when the ceiling goes up the trim slides up and you never see a crack.
Then as the weather changes the ceiling comes back down and the trim slides down.
Roy Cooke
Old 2/26/08, 8:43 PM
Banned
hope this helps.
Russell:
You hid the movement with the tape, not fixed the problem. I've seen some movement of 1/2"+ and have heard of up to 3/4".+.....your tape would not hide this type of movement.
There is a "fix" ("floating" the ceiling corners) at drywall installation which hides the movement.
baqck in the mid-1980's, I saw another "fix" specified by a construction super in a single family residence for our national police force, the Mounties. His idea......install joist hangers over the truss bottom chord and screw them into the top plates of the central interior walls! It kept the crack from appearing at the top wall/ceiling joint.....but one section of wall lifted off the floor 3/16-1/4"!!!! Well, no crack to repair/hide at the wall tops.......just hope there was enough slack in any wiring/pipe systems.
Interesting unusual truss design badair Structural Inspections 3 2/19/08 4:34 AM
Truss uplift jlybolt Structural Inspections 2 3/29/07 8:43 PM
Best Truss Repair Ever!!! srowe Exterior Inspections 2 10/24/06 10:05 PM
3-2 mono roof truss anchor dthomas2 Structural Inspections 8 10/3/06 12:36 AM
