| Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics. |
Well explianed . Thanks Ari
Homes Vaulted ceiling in older home subject to leaks Newer construction method avoids problem Sun Jan 21 2007 ARI MARANTZ - ASK THE INSPECTOR QUESTION -- I have experienced leakage and somewhat understand insulation difficulties in cathedral ceilings. In my home, I had a serious problem with water causing damage to a kitchen wall. As a result they had to open up the wall and remove the insulation, which was soaked, reinsulate with fibreglass batts and place a vapour barrier over the top. They will not be redrywalling until the spring, in case of further damage because of ice damming. I have only been in the house for five months but am now wondering whether the architecture of a cathedral ceiling is just wrong for our climate in Winnipeg. My house was built in 1959 but certainly they are still building this style of house. Are there better methods now, so that proper insulation can be installed in an atticless house? I am beginning to be very concerned that I made a bad decision about the house and will continue to have related problems including higher-than-normal heating costs to a comparable house without cathedral ceilings. Do you steer people away from such houses when you do building inspections for people? Your comments would be appreciated. --Fred S., e-mail ANSWER -- To answer your last question, first, the role of the home inspector is not to "steer" people away from or toward buying a particular home or property. Any inspector that does is improperly exceeding their authority. The role of the inspector is to identify defects, health and safety concerns, and other issues that may lead to substantial costs to their clients. It is up to the buyers to make the ultimate decision to proceed with the purchase, which may be partially based on the results of the home inspection. I do, however, advise clients of the higher likelihood of experiencing ice damming and leakage issues with an older-style vaulted ceiling, like yours. The interesting thing about homes with vaulted ceilings, particularly the ones built around the same time as yours, is that some experience considerable ice damming and leakage and others only have minimal problems. This may be a function of the insulation materials and methods used to insulate these attic-free roof systems. It may also be a function of the overall design of the home, and to a lesser extent, the lifestyles of the occupants. document.write(''); if ((!document.images && navigator.userAgent.indexOf('Mozilla/2.') >= 0)|| navigator.userAgent.indexOf("WebTV") >= 0) {document.write('<a href="http://ad.doubleclick.net/jump/site121.tmus/;tile=6;sz=300x250;pos=6;ord=123456789?" target="_blank">The second method of insulating a vaulted ceiling is to completely pack the cavity between the ceiling joists with insulation and install as tightly-sealed an air-vapour barrier as possible on the underside of the joists, behind the drywall. The roofs insulated in this manner, with just fibreglass batts, are often the most problematic. Warm air will inevitably penetrate this cavity from the living space and cause problems. Often, excess condensation will also occur in between the ceiling joists, causing major moisture damage to the roof sheathing. The good news is that homebuilders have learned this, and can now provide a problem-free roof system design with a vaulted ceiling. These roof systems have scissor-shaped roof trusses that have a higher pitch on the top cords of the truss than in the lower cords. In plain language, these roofs systems are steeper on the outside of the roof than the ceiling below, which allows for a much larger area in between the roof and ceiling. This enlarged area will allow for insulation and ventilation similar to an attic above a typical flat ceiling. This eliminates the excess condensation and warm air buildup above the ceiling, noted in the older roof designs. The adequate room for ventilation will ensure a cool roof deck and eliminate the potential for large ice dams. No ice dams or condensation form and no more water leaks into the home from the roof system. Other than building a new home, there are other new advances in building science that may provide relief for homes like yours that have minimal room for proper ventilation in a vaulted ceiling. Many studies in recent years have identified air leakage from the living space as the major cause of the type of problems you are experiencing. This is due to the moisture that is carried by this warm air, which will condense when it penetrates deeply enough into the insulated ceiling. This condensation may freeze in the winter and cause major moisture damage as it melts. Fibreglass batt insulation, which is good at minimizing heat loss, does not prevent air movement. Also, small openings or gaps in the ceiling or polyethylene will lead to air leakage into the roof system. The only permanent solution is to stop air leakage into this area, rather than attempting to eliminate this leaked air with ventilation. The use of blown-in, expanding foam insulation for this type of roof may fix the leakage problem. These foams, normally a type of closed-cell polyurethane, can be installed above the ceiling. Most are excellent air-vapour barriers and insulators and, due to their expansion during application, can fill even the smallest gaps or spaces to minimize air leakage from the home. The only drawback is that it may be quite costly to install this type of system as it is normally done from the exterior of the roof and large portions of the roof sheathing have to be removed for installation. Often, the cost is highly justifiable if it prevents major moisture damage to the home from constant leakage. Ari Marantz is the owner of Trained Eye Home Inspection Ltd. and the president of the Canadian Association of Home & Property Inspectors - Manitoba (www.cahpi.mb.ca). Questions can be e-mailed or sent to: Ask The Inspector, P. O. Box 69021, #110-2025 Corydon Ave., Winnipeg, Man. R3P 2G9. Ari can be reached at (204) 291-5358. trainedeye@iname.com Roy Cooke .... Join NACHI be HAPPY If I can answer any questions please send me email Roycooke@hotmail.com On an inspection and need immediate help call my cell 613-827-2011 |
Interesting that you should post this Roy. I ran across this very problem YESTERDAY! As an added bonus all of the rafters were outlined in dark grey on the inside of the ceiling. Being quite cold in these parts yesterday, i was able to scan the ceiling with my I.R. thermometer and show that there was a 20 - 33*F difference in temperature between the "rafters" and the areas between.
(In the end I think the pervading smell of cat pee that may have scuppered the deal |
Oh sure George, blame it on the natural biological functions of a cute defenseless animal.
Chuck Crooker I.M.M., Canadian Home Inspectorhttp://www.crookerhancox.com "Not just an inspection, an Education!!!"
You can use a blue light to find the urine. I believe urine stains will floress (sp) under blue light?
| Batt insulation over suspended ceiling | smcarthur | Interior Inspections | 7 | 3/11/11 10:58 AM |
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 7:45 PM |
| Nail pops at the base of vaulted ceiling-no roof leak | kshepard | Interior Inspections | 29 | 9/9/07 3:06 PM |
| New Old Insulation | rcooke | Canadian Inspectors | 1 | 12/13/06 6:25 PM |
| Crawlspace Insulation | gbrasseur | Structural Inspections | 12 | 12/3/06 4:18 PM |
