Go Back   InterNACHI Inspection Forum > Local Inspection Issues > Canadian Inspectors
Canadian Inspectors This is a place for Canadian InterNACHI inspectors and other inspectors in Canada to discuss local inspection topics.
Old 11/23/06, 10:04 PM
Charles R. N. Crooker's Avatar
Charles R. N. Crooker Charles R. N. Crooker is offline
Default Water Heater Mixing valve?
I am looking for the date that the mixing valve for the gas water heaters became code for Ontario, thanx in advance.
Chuck Crooker I.M.M., Canadian Home Inspectorhttp://www.crookerhancox.com "Not just an inspection, an Education!!!"
Old 11/23/06, 10:09 PM
Roy D. Cooke, Sr's Avatar
Default Re: Water Heater Mixing valve?
Memory tells me it was Jan 1 2005 . I think if the permit was taken out before that it might not apply. They at this time are still replacing water heaters that are worn out and not putting in the valves . The laws says they must.
Another trick if you can not get the water hot enough from the mixing valve take the red cover of and there is an adjustment inside .
Roy Cooke
Old 11/23/06, 10:43 PM
Claude Lawrenson's Avatar
Claude Lawrenson Claude Lawrenson is offline
attached read q/a #4
Old 11/23/06, 10:52 PM
Great Thanks Claude Missed you have you been away Hope every thing is fine.
Roy Cooke
Old 11/24/06, 6:04 AM
Thanx Claude and Roy!
TPR valve acox Plumbing Inspections 19 5/27/07 1:36 PM
Venting an oil-fired water heater mh718 Inspecting HVAC Systems 3 11/16/06 10:36 AM
TPR & Combusiton Air thejnicki Plumbing Inspections 16 9/18/06 9:55 PM
small valve on cold water supply ahead of water heater? Walt Hoffman Plumbing Inspections 6 1/23/06 8:44 AM
