Go Back   InterNACHI Inspection Forum > Miscellaneous Inspection Topics > IAC2 Indoor Air Forum
IAC2 Indoor Air Forum This forum is hosted by InterNACHI for members of the International Association of Certified Indoor Air Consultants.
Old 11/14/09, 9:00 AM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Construction Mold
Would say this was construction mold? Home is 15 years old. Several areas on b floor joist. Home has been vacant for sometime. Should I recommend a mold test?
Thanks!
Mid America Property Inspections, Inc.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Find an InterNACHI certified Maryland Home Inspector (and anywhere else in North America)
Old 11/14/09, 9:38 AM
James E. Braun, CMI's Avatar
Default Re: Construction Mold
Yes, most likely that lumber was installed originally with some mold on it and this mold just grew larger as the environment allowed. Plywood because of the air gaps between plys (retains moisture better) and the glue used (supposed better desired food for mold) will grow mold faster and at a lower humidity and wood moisture level then framing lumber.
Yes, I would recommend testing by somebody who is certified to do so.
Old 11/14/09, 9:55 AM
James,
Thanks! I did.
Shawnee, KS 66217
www.mapii.com
NACHI # 05110992
KHIRB # 0110-0008
Interesting article about mold by litigation. gromicko IAC2 Indoor Air Forum 16 5/5/11 7:48 PM
Fighting Mold — The Homeowners' Guide from CMHC mkyriacou IAC2 Indoor Air Forum 1 9/17/09 2:32 PM
GAO calls for collaboration on indoor mold guidance. gromicko Legislation, Licensing & Legal Issues for Inspectors 32 11/11/08 8:47 AM
The new scoop on mold insurance Brian A. MacNeish Ancillary Inspection Services & Additional Topics 2 1/1/08 1:30 PM
CMI imposter? jbraun Certified Master Inspector (CMI) Discussion 118 11/26/07 4:55 PM
