| IAC2 Indoor Air Forum This forum is hosted by InterNACHI for members of the International Association of Certified Indoor Air Consultants. |
Once you get the results back, and your customer asks you to explain what all the numbers mean, and to interpret the labs report, how in depth do you go?
Jim Maryland Home Inspection Services Inc. www.MarylandHomeInspectionServices.com State of Maryland License# 31141 Virginia License#3380 000468 National Association Of Certified Home Inspectors ID: NACHI10101807 International Association of Certified Indoor Air Consultants (IAC2). Certification # IAC2-02-0919 Maryland Home Inspectors In Gaithersburg, Rockville, Germantown, Bethesda, Potomac, Also All of Northern Virginia and Washington, D.C. |
| Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
I actually write a letter that goes ahead of the lab results explaining the results and what the next actions, if any, should be taken, but my training is more extensive than the average home inspector. I would think a regular home inspector would just hand off the lab results and that is it. Interpreting lab results can hold a lot of liability if the inspector is not trained on how to interpret them correctly. Interpreting lab results is usually the hardest part of my job.
Braun Inspection Consultants Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Infraspection Institute Level 1 Certified Infrared Thermographer Fogarty Inspection Services Group of Knoxville TN Home inspections, Commercial Inspections, Thermal Imaging, Mold, Enviromental Testing and Radon Testing for Knoxville TN, Oak Ridge TN, Maryville, Clinton, Farragut, Lenoir City, Pigeon Forge, Sevierville and all the surrounding areas. 865-256-5397 www.homeinspectorknoxville.com www.moldandradon.com www.thermal-inspection.net www.commercial-building-inspector.net |
What did the tests come back with?
I use EMSL and their reports are fairly detailed. My question is how far do you go with trying to explain to the client what all the different results and test levels mean ? I am not talking about trying to find the source of the moisture causing the molds, I am referring to only the actual report findings?
Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
No but he works with one every week.
If not a CIH
you should not be interpreting laboratory results.. If you do and you are not you better have E&O and then that may not protect you..... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
I tell them if the result for any mold count is higher indoors than outdoors then mold growth indoors can be assumed and a more thorough investigation by a mold remediation specialist or IH should begin.
I do not get into the hazards associated with particular molds...I refer them to the report for that (I use EMSL also). “The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life.” Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
I would refer them back to the lab that did the test
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas Active Rain Member |
Actually an Industrial Hygienist has only eight hours of education in mold when he gets his degree. My Industrial Hygienist, who is the top mold expert in the Missouri, use to teach that class in an university. The word "industrial" is a giveaway what an Industrial Hygienist really is. I honestly believe a regular home inspector who just takes the NACHI mold courses knows more about mold then the average Industrial Hygienist. I have taken a lot of classes with Industrial Hygienists and I can say that most IHs have no idea what they are doing when it comes to mold. Sad but true.
James K. -
YOU should not be detailed / just explain basics - Then refer to others UNLESS you are competent to write and dictate protocols for others which you've already shown you're not by simply asking (most are not). Sample cover letter attached. The lab reports are very EASY to read. ____________________________________________ August 4, 2010 To: Joe Blow XXXX Belleview #346789 Kansas City, MO 64111 Re: Mold / Air Sampling @ XXX McGee @ Kansas City, MO 64111 Dear Joe: Per your request, on 8/2/10 we took certain air samples at the above referenced property and submitted them to “Pro-Lab Company” for evaluation. The purpose was to determine within reasonable limitations if there were traces of mold spores present, and how that compared to the outside air. Copies of their reports are attached. The samplings we took were as follows: (1) an Air Sample of the Outside Air to function as a benchmark; (2) an Air Sample at the unfinished basement; (3) an Air Sample at the 3rd floor apartment; and (4) a Swab Sample at the SW Basement Wall area with stains. There were water stains at the basement and a mildew / mold odor present at that area. As you can see in the lab report following this letter, there was definite evidence of ELEVATED or UNUSUAL MOLD SAMPLES present inside at both levels sampled (Penicillium / Aspergillus). Although Penicillium / Aspergillius is often a simple Allergenic Mold, with the extremely high counts present it should be considered a significant concern. Mold clean-up should be dealt with by Professional Mold Contractors. We recommend contacting a specialist dealing in mold clean-up or removal for service and guidance in the , remediation and correction of these issues. The yellow pages has many of these type of companies listed. Two companies we’ve frequently seen are Air Quality Assessment - (913) 962-1028 (Chris Bieber) and Mold Busters & Analysis - (816) 516-554-6653 (Pat Murphy) The Air / Mold Sampling we performed only screened the air at specific locations. The sampling was not intrusive or destructive. It did not include concealed areas or latent growth inside walls, etc. It is not intended to replace medical advise or to make claims about your future health in the property. Dan Bowers Dan Bowers, CRI Enclosure: (1) The Lab testing results of the mold/air samplings |
Thanks Dan, that is pretty much what I have been doing, I wanted to see if I was in the norm regarding the depth of lab interpretations others give to their clients.
I limit my liability by generalizing and not stating anything that's not in the lab report. "The living room area was air sampled and show elevated levels of ....
| Builder messed up, and blames me! | wdecker | Miscellaneous Discussion for Inspectors | 137 | 11/9/09 2:59 PM |
