Go Back   InterNACHI Inspection Forum > Miscellaneous Inspection Topics > IAC2 Indoor Air Forum
IAC2 Indoor Air Forum This forum is hosted by InterNACHI for members of the International Association of Certified Indoor Air Consultants.
Old 6/16/11, 2:37 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default High humidty in House 72% Rh, creating mold to leather shoes in closet.
Anybody ever dealt with this situation?
House and closet from my senses were stuffy.
There was not a water leak problem...no water intrusion.
The temperature of the closet was 68 degrees and the Rh was 72%
The outside temperature was 90 degress with a RH of 33%.
A pair of leather shoes had mold growth. I took a sample and
Im waiting for the results.....
Is the solution as simple as opening the windows of the house?
David
Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/16/11, 3:08 PM
Roy D. Cooke, Sr's Avatar
Default Re: High humidty in House 72% Rh, creating mold to leather shoes in closet.
I would say best idea is an auto dehumidifier set at 50 % RH with a hose to drain the water away .
Who would close the windows when it rains .
A larger gap under closet door would not hurt.
Old 6/16/11, 3:13 PM
Joe Funderburk, CMI's Avatar
My parents bedroom closet was like that for years. It backed up to a bathroom with a vent stack in the wall. Turned out the vent had a small leak every time it rained. After years, mold inside the bathroom cabinets revealed itself and there was also extensive damage to the sub-floor.
Caution Will Robinson!
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 6/16/11, 7:11 PM
measter measter is offline
Please Note: measter is a non-member guest and is in no way affiliated with InterNACHI or its members.
In my neck of the woods this problem is almost always related to very high infiltration levels in the home and a too moist crawl.
The stack effect is drawing in air from the flooded crawlspace (leaky ductwork, poor grading, clogged gutters, inoperable sump, and no vapor barrier) 24-7.
I can almost diagnose it over the phone. Of course the problem is not the mold on clothes. The problem is the subfloor and Rim joist that is rotting to the ground.
Now if you tell me that don't have a basement or a crawl, then you need to look elsewhere to track down the high humidity levels. Low natural leakage with no ventilation in humid rooms? Not running the AC? Running the fan constantly even when the ACs not on?
I never thought of taking a sample; Hmm?
What would I do with the results? If the sample results will not change my course of action, I don't take a sample.
FWIW,
Mark
Old 6/16/11, 11:04 PM
James E. Braun, CMI's Avatar
I got involved last year with a case between a builder and a new home owner. One of the so called experts hired by the builder said the mold was being caused by the fan on the air handler running all the time. I remember reading a study that actually concluded differently and after a few hours of looking I found it. If I ever run across the study again I will post it. Actually the constant air movement reduces the humidity levels. That is why you will find more mold in closets or under stair wells and such, because the air is stagnant. Other than that Mark has it about right.
Dehumidification will need to be performed such as Roy says but the dehumidifier should be set about 35% instead of 50. During the hot time of the year, the cold air of the inside meets with the hot air from outside and will create higher humidity inside the outer walls or along the inside surface of the outer walls. So to keep mold from growing the inside humidity needs to be kept below 40%.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 6/17/11, 3:11 AM
FWIW,
Mark
Thanks for the info.
Old 6/17/11, 3:12 AM
Great info...
Old 6/20/11, 9:18 PM
Jeff Merritt Jeff Merritt is offline
I run into this from time to time, installing a louvered door helps, tell clients not to pack the closet wall to wall and leave an air space around the walls.
Old 6/20/11, 11:02 PM
David A. Andersen's Avatar
The outside temperature was 90 degrees with a RH of 33%.
Quite simple actually...
Both the 68 degree air and the 90 degree air have the same heat and moisture.
(+/- 4 btu/lb and 3 grns/lb) (I'm sure your measurement error factor covers this).
Closet air is just not getting to the HVAC equipment.
Actually it does not. But seeing running the fan helps in other ways, we'll just leave it at that.
BPI# 5015804
Old 6/20/11, 11:28 PM
Basements Are An Invitation For Mold
Damp Basements Are An Invitation For Mold
Basement Mold Will Grow Even If There Have Never Been Flooding or Leaks.
Many people associate mold in basements with flooding. Although flooding, leaky pipes, leaky roofs and clogged gutters are certainly contributors to mold growth, many times the main culprit is excessive basement humidity. Regardless the air temperature, there will always be cold concrete floors and wall materials that take on the ground temperature of the soil around your home. A damp basement can provide an inviting environment for mold growth. Mold grows the fastest in your basement when there is lots of moisture. It can grow on many surfaces, including walls, floors, carpets, ceiling tile, wallpaper and insulation.
  • Have you ever opened the basement door and noticed the musty smell of your basement even though it looks completely clean?
  • No matter how much you vacuum floors and clean surfaces, do you find that the odor is still there?
The most common place for mold growth is beneath carpet, behind drywall and behind insulation. Basement mold grows directly on the concrete floor, cinder block, brick or concrete walls and beneath pipe insulation.
Molds are microscopic organisms that are a type of fungi. There are over 100,00 species of mold and mold spores are so minute that as many as 250,000 can fit onto the head of a pin! Besides negatively affecting your health, molds can damage your home. They can eat through basement insulation, wood framing, carpeting and other organic matter. When molds eat this organic matter they emit volatile organic compounds (VOC’s) that contribute to poor air quality.
You can usually detect mold in your basement by smell or sight. Spots on walls, floors and carpets are indications of mold infestation. Molds produce a highly noticeable damp, musty odor that in extreme cases can be overpowering. Peeling paint and stained wallpaper are other indicators of mold growth. Many homeowners make the mistake of painting over mold. Out of site out of mind doesn’t apply here. Painting over mold is a poor mold remediation solution because mold will feed on the paint itself.
If you do have mold in your basement don’t feel alone. The American Society of Home Inspectors estimates that 60% of U.S. homes have wet basements. Even well built and sealed basements that would not have mold under normal circumstances can develop mold growth from high humidity. Many basements feature concrete walls and floors. Unfortunately, concrete is a porous substance that can trap moisture and provide a home for mold growth. Wet basement walls and floors are usually signs of condensation caused by high humidity.
The optimal humidity level in your basement should be below 50%. You can check the humidity level in your basement with a humidistat. The best way to accomplish 50% or less humidity is with a good quality basement dehumidifier. The Dri-Basement dehumidifier can handle the heavy moisture loads in large, damp basements. By removing the moisture from the air in your basement, you deprive mold a suitable environment to live in. This commercial grade basement dehumidifier can keep your basement dry and mold free.
When you install the Dri-Basement dehumidifier there are things you can do to help its performance. Make sure all windows and doors to your basement are tightly sealed to stop outside air from entering. Remove any wet or damp items from your basement. It is also very important to vent your clothes dryer. Unvented dryers create a warm, humid environment conducive to mold growth.
Use a Dri-Basement dehumidifier to make your basement a more clean and comfortable area. Remember, a dry, clean smelling basement not only provides additional living and storage space, but it can increase the value of your home.
Old 6/21/11, 12:36 AM
Robert Ernst Robert Ernst is online now
I wouldn't run a dehumidifier I would find the source of the water. If I had to bet there is either moisture in the crawl space or a leak some place near the closet. There is to far of a difference between inside and outside in my opinion.
Old 6/21/11, 2:01 AM
There is only a 0.509 grain/cu ft of moisture difference between the indoor and outdoor air.
I hope you don't think that a 33% to 72% RH difference has anything significant to do with the differential of moisture in the air!?
If you can't get the air into the air conditioner, a dehumidifier (same as an a/c excepts it heats up the house) is your only choice.
BPI# 5015804
Old 6/21/11, 12:13 PM
David,
At 68 degrees at 72% humidity that would defiantly create enough moisture to cause mold to grow.
Old 6/21/11, 1:00 PM
"Show me" ; you are from MO... !
Do you think I make this stuff up?
I never said it wouldn't. I said that the source of the moisture is from the outdoor air, not a catastrophic water leak somewhere that no one found...
I also said the HVAC is not performing in the closet.
Someone said to change the door...
I said you need a source of dehumidification because of this problem.
Can you read one of these?
That didn't print right; AW is Grains/cu ft.
The grains of moisture in the air would considerably increase from 33% to 72%.
Why? It has nothing to do with the quantity of moisture in the air. It is about the capacity of the air to hold moisture.
BPI# 5015804
Old 6/21/11, 5:14 PM
Wayne B. Wilson's Avatar
Would it not be simple to condition the area if a walk in or vent the door. Should be the first thing i would think .
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Mold in the attic rmichaud Canadian Inspectors 46 10/25/10 1:47 AM
Dr. Shane says every home should be tested for mold. gromicko Ancillary Inspection Services & Additional Topics 106 6/7/09 3:36 AM
Stupid ASHI legislatin in Washington DEAD. gromicko Legislation, Licensing & Legal Issues for Inspectors 20 1/29/08 9:05 AM
Everyday Events Can Cause Mold jmckenna1 Miscellaneous Discussion for Inspectors 1 3/3/07 2:11 PM
Family's house is infested with mold rspriggs Ancillary Inspection Services & Additional Topics 6 1/28/06 2:05 AM
