Go Back   InterNACHI Inspection Forum > Miscellaneous Inspection Topics > IAC2 Indoor Air Forum
IAC2 Indoor Air Forum This forum is hosted by InterNACHI for members of the International Association of Certified Indoor Air Consultants.
Old 2/11/10, 7:21 PM
mruffing mruffing is offline
Default Meth Lab test
Does any on know were I might get a test kit(s) to see if this home I am inspecting was a METH Lab?
FORESIGHT HOME INSPECTION Inc
Michael Ruffing C.M.I
Johnson City, Tn
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/11/10, 8:15 PM
Sean Fogarty's Avatar
Default Re: Meth Lab test
Emsl sells them. You might be able to get one for free if you pay to have them test it. Be aware. The state of TN only recognizes state certified and licensed testers. Your test can be for general reference, but if you do find anything then the state would have to test for it to be legit. that would be expensive. You also should be aware, if you screw up and say nothing found, and it was a meth lab your in hot water. TN says that anything above .01 micrograms in not habitable. I would recommend you inform you clients of this before you test.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 2/11/10, 9:18 PM
Sean
Thanks
I will pass it on to the right people and let them worry about it.
Johnson City, Tn
Old 2/28/10, 9:20 AM
Philippe G. Heller's Avatar
Philippe G. Heller Philippe G. Heller is offline
So what are the tell-tale signs of a potential meth lab?
The following signs might be obvious, but are there any otheres?
Disconnected smoke alarms
Bluish color on copper
Staining running down the walls (like moisture in a bathroom)
Odors
I'd hate to miss it, but on the other hand I would hate to recommend testing with little evidence. This could cause a buyer to back out, and if I'm wrong it could get me in hot water.
Philippe Heller
The San Diego Real Estate Inspection Co.
http://www.sdinspections.com
www.facebook.com/sdinspections
Old 2/28/10, 9:32 AM
Wayne B. Wilson's Avatar
http://www.rid-meth.org/frmSearchSite2.aspx
Try this also
Old 2/28/10, 10:45 AM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
Odors
The tweaker hiding in the closet is usually a dead giveaway!
I can not honestly say, I have not run into this situation before, but have read of some nightmares from other inspectors.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Meth House? tallen General Inspection Discussion 27 4/6/09 6:21 PM
Health officials want meth history on house listings dplummer IAC2 Indoor Air Forum 0 8/20/08 7:08 PM
Meth Cleanup Bill Passes dplummer IAC2 Indoor Air Forum 3 2/6/08 12:15 AM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
