Go Back   InterNACHI Inspection Forum > Miscellaneous Inspection Topics > IAC2 Indoor Air Forum
IAC2 Indoor Air Forum This forum is hosted by InterNACHI for members of the International Association of Certified Indoor Air Consultants.
Old 9/14/09, 12:50 PM
John M. Acaron's Avatar
John M. Acaron John M. Acaron is offline
Question MOLD TESTING? CONDO air sampling
If you are performing air sampling on the 18th floor, where do you take the control sample? 18 floor balcony or on the first floor (outdoor)?
Following IAC2 protocol???
Find an InterNACHI certified Michigan Home Inspector (and anywhere else in North America)
Old 9/14/09, 5:56 PM
Douglas Wall Douglas Wall is offline
Default Re: MOLD TESTING? CONDO air sampling
at least 10 feet from structure IESO standards (ANSI approved)
at least 5 feet from structure ESA standards
can't remember what IAC2 says
We have dozens of home inspectors in the Naples area that take them on the balcony but then what's a nationally accepted industry standard.
Radon & Mold Professionals
Doug Wall, CIE
ACAC certified Indoor Environmentalist
Florida Licensed Mold Assessor # MRSA 2
Florida Licensed Home Inspector # HI2202
We do not do Home Inspections
www.radonmoldhelp.com
Radon Testing - Mold Assessments - Mold Inspections - Mold Sampling - IAQ Assessments /Allergen/VOC/Drywall Assessment
www.naplesmoldinspection.com
Old 9/14/09, 9:06 PM
James E. Braun, CMI's Avatar
I believe for some weird reason IAC2 makes you take two outdoor samples. I usually take samples at least 20 feet away, I cannot remember where I got that from.
Also stay away from trees and straw as much as possible.
Old 9/14/09, 9:55 PM
Talking Re: MOLD TESTING? CONDO air sampling
That is not the question. I am talking about a 20 story condominium. Do you take the control sample outside the building 1st floor or do you take the control sample on the balcony in the 19th floor. That got to be a heck of a tree to be over 300 feet tall.
Old 9/15/09, 8:43 AM
Question Re: MOLD TESTING? CONDO air sampling
Still looking for a rational answer??????
Old 9/15/09, 9:00 AM
We have done hundreds of condos up to the 27th Floor. (over 800 inspections each year)
The balcony is NOT at least 10 feet from the structure.
HI usually take samples on the balcony because they need a plug for their pump.
Makes someone look pretty dumb when you go behind them and don't take the outdoor sample on the balcony. Someone always asks why we don't take the sample on the balcony. If you end up in litigation and are asked why you took the sample on the balcony, what do you say " I didn't want to follow nationally accepted standards". We often do design our own testing plans but then we are not home inspectors.
Hope that answers the question.
Doug Wall, CIE
Old 9/15/09, 9:58 AM
Thanks Doug,
When dealing with condos I normally take the control sample at least ten feet away from the building bottom floor. However, it is the consensus in our area for what I have seen that other folks take the sample on the balcony, sometimes 300+ feet up.
It is my opinion that the level of spore counts will be less due to higher wind and so far high from trees and other possible attributes to spore count. What is your take on this.
Old 9/15/09, 9:57 PM
David Moriconi's Avatar
David Moriconi David Moriconi is offline
2 outdoor samples may just help the lab make more money. My rep at Pro Lab says two outdoor samples are not needed for their lab
David Moriconi
M3 Real Estate Inspection, LLC
816.665.5346
www.m3inspect.com
iNACHI Certified Residential Inspector
NRSB Certified Radon Measurement Specialist Certified Mold Inspector
Old 9/16/09, 12:14 AM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
ESA courses teach that you are not supposed to take sample under and overhanging part of the structure. I believe the IAC2 standard also states that.
I always take my control sample at ground level and by the street side of the buildinging. If the unit is tucked away in a courtyard or in an area that has less air circulation, I will take a second outdoor control sample and not charge extra for it just so that I can see the difference between that and the street level sample.
Anotehr bit of advice...If you are going to seriosly do mold sampling and environmentla testing...cut your ties with Pro-Lab and find another laboratory that all the local industrial hygienist use. I don't know about you, but I don't want some lab tech sitting behind a microscope that doesn't read any of the noted on the COC form interpretating what I found at an inspection. There are times when I used to use them that my findings conflicted with their analysis. You might want to send in the occasional field blank and see if you get a positive result back. If you do...move on to another lab who is more qualified and takes the proper precautions not to give out false results.
Interesting article about mold by litigation. gromicko IAC2 Indoor Air Forum 16 5/5/11 8:48 PM
Mold mcyr IAC2 Indoor Air Forum 5 9/13/10 11:31 AM
Mold Testing Kansas City dmoriconi Ancillary Inspection Services & Additional Topics 0 1/11/09 2:44 PM
The new scoop on mold insurance Brian A. MacNeish Ancillary Inspection Services & Additional Topics 2 1/1/08 2:30 PM
CMI imposter? jbraun Certified Master Inspector (CMI) Discussion 118 11/26/07 5:55 PM
