Go Back   InterNACHI Inspection Forum > Miscellaneous Inspection Topics > IAC2 Indoor Air Forum
IAC2 Indoor Air Forum This forum is hosted by InterNACHI for members of the International Association of Certified Indoor Air Consultants.
Old 10/6/11, 8:30 PM
David Nasser's Avatar
David Nasser David Nasser is offline
Default Mold testing....Customer calls back for advice. Question..
I performed a mold test for a client. The test comes back
positive, for toxic mold. I also recommended a further evaluation
because it looked like they have mold behind the drywall.
The client called his landlord to remediate the problem. The landlord
tells the client its not his concern and will not fix the problem.
The client called me and says his landlord does not care and will
not fix anything....What is good advice for me to tell the client?
David
An Ounce of prevention is better
than a pound of cure :}
Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 10/6/11, 8:38 PM
James H. Bushart's Avatar
Default Re: Mold testing....Customer calls back for advice. Question..
David
Tell the client to consult with an attorney and explain that you are an expert on homes and not the laws that concern them.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 10/6/11, 8:59 PM
Stephen W. Stanczyk's Avatar
California has some pretty strict landlord / tenant laws. Send them here for information.
http://www.dca.ca.gov/publications/l...ok/index.shtml
Stephen Stanczyk
Old 10/6/11, 9:06 PM
James E. Braun, CMI's Avatar
In Missouri, I advise them to read their contract. In most contracts the landlord has to supply the tenant with a safe place to live. If the landlord does not, he is breaking the contract and the tenant can give the landlord notice. I have had a few landlord's threaten to sue the tenant if he moved. After I wrote a report with pictures, the tenant was glad to see the tenant go. The real smart landlords helped them move. It is all how you word the report. I may not be a lawyer but I can get the landlord's attention.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 10/6/11, 10:31 PM
Thanks for the info.
Old 10/6/11, 10:32 PM
Thanks Steve
Old 10/11/11, 8:53 PM
Pete Campbell's Avatar
Pete Campbell Pete Campbell is offline
tell them to get a liar, err, lawyer.
Pete Campbell
pete4545@comcast.net
http://www.PortStLucieInspections.com
http://www.ChooseGI.com
http://ifwemissitwewillfixit.com
Inspecting Fort Pierce, St. Lucie Village, Lakewood Park, Vero Beach, Indian River Shores, Sebastian, Fellsmere, Fort Drum, Okeechobee, Jensen Beach, Stuart, Palm City, Hobe Sound and Indiantown, Florida.
Old 10/18/11, 7:38 AM
Douglas Wall Douglas Wall is offline
EPA Considering Bioaerosol Sampling
"remember that a negative sampling report must not be used in place of a visual survey. Factors such as barometric pressure, inside and outside temperatures, activity levels, and humidity may dramatically reduce or increase the spore levels within a building. Air sampling for mold provides information on what was in the air only for the moment when the sampling occurred. It is important, therefore, that sampling not replace visual inspection."
We see several a month, year after year after year where home inspector air sampling for mold (mold test?) indicates a need for further investigation, and there is nothing there.
We will not trust a home inspector's sampling report, just can't do it.
Take their money and don't worry about it.
Radon & Mold Professionals
Doug Wall, CIE
ACAC certified Indoor Environmentalist
Florida Licensed Mold Assessor # MRSA 2
Florida Licensed Home Inspector # HI2202
We do not do Home Inspections
www.radonmoldhelp.com
Radon Testing - Mold Assessments - Mold Inspections - Mold Sampling - IAQ Assessments /Allergen/VOC/Drywall Assessment
www.naplesmoldinspection.com
Old 10/18/11, 8:21 AM
John Harrison's Avatar
John Harrison John Harrison is offline
Many cities require rental property to comply with international building maintenance code. Chech with or refer them to you local building department
Performing Home Inspections in Council Bluffs, Missouri Valley, Glenwood, and surrounding areas
Active Rain Member
Old 10/18/11, 8:39 AM
Barry Adair's Avatar
when will the logo mills and the q-tip cowboys assure education and factual consumer information that stresses
The term "toxic mold" is not accurate.
oh wait that would cut into profits
CDC first bullet point: http://www.cdc.gov/mold/stachy.htm#Q1
While certain molds are toxigenic, meaning they can produce toxins (specifically mycotoxins), the molds themselves are not toxic, or poisonous. Hazards presented by molds that may produce mycotoxins should be considered the same as other common molds which can grow in your house. There is always a little mold everywhere - in the air and on many surfaces. There are very few reports that toxigenic molds found inside homes can cause unique or rare health conditions such as pulmonary hemorrhage or memory loss. These case reports are rare, and a causal link between the presence of the toxigenic mold and these conditions has not been proven.
In 2004 the Institute of Medicine (IOM) found there was sufficient evidence to link indoor exposure to mold with upper respiratory tract symptoms, cough, and wheeze in otherwise healthy people; with asthma symptoms in people with asthma; and with hypersensitivity pneumonitis in individuals susceptible to that immune-mediated condition. The IOM also found limited or suggestive evidence linking indoor mold exposure and respiratory illness in otherwise healthy children. In 2009, the World Health Organization issued additional guidance, the WHO Guidelines for Indoor Air Quality: Dampness and MouldExternal Web Site Icon [PDF, 2.52 MB].
A common-sense approach should be used for any mold contamination existing inside buildings and homes. The common health concerns from molds include hay fever-like allergic symptoms. Certain individuals with chronic respiratory disease (chronic obstructive pulmonary disorder, asthma) may experience difficulty breathing. Individuals with immune suppression may be at increased risk for infection from molds. If you or your family members have these conditions, a qualified medical clinician should be consulted for diagnosis and treatment. For the most part, one should take routine measures to prevent mold growth in the home.
ADAIR INSPECTION
972-487-5634
TREC # 4563
EDI: EIFS-MA TX # 39
2008 US Member of the Year
Old 10/18/11, 6:39 PM
William Warner's Avatar
William Warner William Warner is offline
Agree BA.
"Q-tip cowboys"... LOVE it!!!
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Mold Inspectors in Coeur d’Alene, ID 83815 rspriggs Ancillary Inspection Services & Additional Topics 15 1/3/12 1:14 PM
State to study toxic mold dplummer Ancillary Inspection Services & Additional Topics 0 12/4/07 9:02 AM
Classes/ Education for Mold bwieczorek Miscellaneous Discussion for Inspectors 6 9/10/06 2:01 AM
Arizona, one day mold cert dbucknavich General Inspection Discussion 4 6/26/06 9:32 PM
