Go Back   InterNACHI Inspection Forum > Miscellaneous Inspection Topics > IAC2 Indoor Air Forum
IAC2 Indoor Air Forum This forum is hosted by InterNACHI for members of the International Association of Certified Indoor Air Consultants.
Old 9/13/11, 4:09 PM
John Gromkoski's Avatar
John Gromkoski John Gromkoski is offline
Default Outside Control Sample
I was wondering what the proper location was for taking an outside control sample when inspecting say a hi or low rise apartment building. Where is the control sample taken? Is it taken at the outside of the main entry door to the building (outside air), outside the apartment's entry door (common hall inside the building), or outside air from the balcony or window? Thanks.
774 Manor Road
Staten Island, NY 10314
718-514-3393
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/14/11, 11:00 AM
Default Re: Outside Control Sample
37 Views and No Replies? Wow.
774 Manor Road
718-514-3393
Old 9/14/11, 12:32 PM
Joe Funderburk, CMI's Avatar
Outside air. Far from the building. Other things to avoid, high wind, recent rain, etc. You may need to take the NACHI course.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 9/14/11, 4:02 PM
Sean Fogarty's Avatar
Apartment buildings can be fun, I just did one. You not only have to worry about the individual dwelling but all the others that surround it as well.
I would also recommend you take 2 outside samples on opposite sides of the building since it is a commercial job. Some can run over 5000 per side wich could make or break an indoor test.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 9/14/11, 7:02 PM
Joe, I have always understood that OUTSIDE/OUTDOOR samples needed to be taken and I completely understand the reasoning for it. The reason for my original question was because I was told by an "expert" that protocol was to take the "outside" sample at the "nearest entry point to the home" and as this expert explained to me that would mean the apartment entry door - even if it was located in an interior common hallway. I questioned him on this statement several times to be clear I understood him correctly. I'm not mentioning where I received this direction but it has certainly made me question this particular organization's credibility.
PS: I'm working through the NACHI course now.
774 Manor Road
718-514-3393
Old 9/14/11, 7:04 PM
Agreed. I think two outdoor samples are called for on this job.
774 Manor Road
718-514-3393
Old 9/14/11, 7:20 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is offline
John I take my samples on the ground level about 20-25 feet away from the building and not near any doors, not under any trees and in an open area as I can find where free flow of air can be obtained.
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 9/14/11, 9:25 PM
Brad Brinke Brad Brinke is offline
What standard are you using? that should tell you
Inspecting Norfolk and Hampton Roads
www.procraftinspections.com
Energy Audits in Norfolk
www.procraftgreen.com
Old 9/15/11, 11:58 AM
James E. Braun, CMI's Avatar
If this "expert" is referring to IAC2 standard than he is right but you need to take two samples outside.
As far as I know, the rest of the mold industry requires only one outside sample at least 20 feet away from any buildings. If you do like Russ says you will be okay.
Just make sure you use some kind of standard when testing.
Braun Inspection Consultants
Serving Jefferson City, Columbia, Sedalia, Fulton and Lake of the Ozarks
Old 9/15/11, 12:04 PM
5,000 what? If it is total or Asp/Pen?
Old 9/15/11, 9:06 PM
Clad had been that way on a couple. I will send you one if you want..
865-256-5397
Old 9/16/11, 9:07 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Apartments are different and you must consider the stack effect. Some mold problems with IAQ come from the hallway. That being said you would need Five samples to get it right. Two Outside as close to the apartment level as possible. This requires coordination with the Owner. Two inside samples in bedroom and living room along with a sample at the entrainment area of the door. The reason is that most apartments are designed with negative pressure not positive. If mold exists in the hallway it will affect the apartment and sensitive occupant. I always recommend an air exchange system installed in the closet with Hepa filtration set at a positive pressure as a more cost effective remedy than spending x amount of dollars on testing.
Carpets removed and no voc laminate flooring can be added with minimal cost along with a no smoke policy on balconies.
You will not find a owner care very often but sometimes they do not want the problem to elevate and scare people from the property.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 9/16/11, 3:40 PM
Yes go ahead. I seldom see Clad at 5,000 let alone 5,000 higher.
Old 9/16/11, 9:17 PM
The standard I follow requires only one outside sample.
When you say two outside samples, do you mean one at the apartment entry door and one outside at ground level. Or both samples in the same location, at the entry door or at ground level?
774 Manor Road
718-514-3393
Old 9/16/11, 9:54 PM
John,
just take 2 samples. One on each side of the building. Its an apartment so it should have plenty of parking space and open areas. If nothing else it will give you some good learning info.
Even if they are fairly close they will always be different. One sample works just fine but if you want to learn then eat one and take 2
865-256-5397
Chinese Drywall Sample Analysis jweissglass Florida Inspectors 16 4/1/10 11:36 AM
World Health Organization says mold is a health hazard. That ends the argument IMHO. gromicko IAC2 Indoor Air Forum 65 8/1/09 6:03 PM
Options in selecting materials for basement construction wdevries Canadian Inspectors 2 8/4/08 1:30 PM
