| IAC2 Indoor Air Forum This forum is hosted by InterNACHI for members of the International Association of Certified Indoor Air Consultants. |
Should the radon discharge pipe extend above the roof line? Should all systems have man-o-meter gauge? What is this pipe I found in the attic, it is at least 75 ft away from the system?
Thanks, for your input. |
| Find an InterNACHI certified New Mexico Home Inspector (and anywhere else in North America) |
Yes it needs a visible indicating device for the home owner to observe that the blower is working and moving air. The pipe may serve as a chase for cable and satellite dish wiring. Where you able to find the other end? You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
The pipe in the attic that says radon mitigation, What's that for?
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
Then it appears the builder provided a pipe between the attic and the lowest level that someone chose not to use.
It is a pre-piped connection in an attic (it appears) to hook up the fan to a pre-installed radon piping system.
They did not use it for this application. They put it outdoors instead. EPA says 2" over the eave. Where is the nearest openable window? Yes a manometer is required to determine if the fan is working. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| Documents on which InterNACHI's radon course content is based: | gromicko | IAC2 Indoor Air Forum | 4 | 1/18/09 6:53 AM |
| Radon Testing Kansas City | dmoriconi | Ancillary Inspection Services & Additional Topics | 1 | 1/11/09 3:11 PM |
| Final review of Newman's radon references! | Caoimhín P. Connell | Ancillary Inspection Services & Additional Topics | 12 | 10/4/08 12:23 PM |
| Radon Class in Oakville and Ottawa | mkyriacou | Canadian Inspectors | 9 | 2/2/08 11:48 PM |
