| IAC2 Indoor Air Forum This forum is hosted by InterNACHI for members of the International Association of Certified Indoor Air Consultants. |
Decided to create new thread.
1 year warranty inspection. Radon piping runs behind garage door header. What would you report and why? Attached Thumbnails
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father Last edited by mlarson; 4/20/09 at 11:07 AM.. |
| Find an InterNACHI certified Florida Home Inspector (and anywhere else in North America) |
I've never seen a radon pipe system go through a garage. Does this pipe penetrate a slab/basement floor? Where's the fan system? The terminating vent should be above the roof line. |
The termination not going through the roof line is the only thing I see with it too. Practically, i don't see that as being an issue where it is, although technically its wrong.
I posted this thread for the purpose of discussion and clarification. He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father |
Ok, I see that the fan is operating normally.
The only thing that stands out is.... the vent should terminate above the roof line. |
And Above the first or second roof line? He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors - Thomas Jefferson - Founding Father Last edited by mlarson; 4/20/09 at 12:35 PM.. |
I would imagine the second (higher) roof line would be better than a lower roof line installation. A lower roof line installation would be improper venting due to the proximity of the sidewall. I wouldn't necessarily tell my client which roof line. I would simply note that a properly installed radon mitigation system must termite above the roof line. I would then recommend a radon mitigation specialist to evaluate and estimate costs of bringing the termination to proper levels. Last edited by dvalley; 4/20/09 at 12:38 PM.. |
Mike,
The highest roof line would be the only solution to this upgrade. The lower roof line will not allow proper ventilation with that wall next to it. http://www.epa.gov/radon/rrnc/index.html |
I think the wording is eave, not rake.
Distance to adjacent windows must be considered. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
From ASTM 1465
http://www.nachi.org/comsop.htm#18
18.7.9 Although I think the real issue here is does the radon pipe in the garage compromise the firewall if/where it passes through to the home. And unlike a mere firewall compromise... a radon fan is pulling 270 cfm... and so makes for a nice fire flue. Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 Last edited by gromicko; 4/23/09 at 2:03 AM.. |
| Radon Testing Kansas City | dmoriconi | Ancillary Inspection Services & Additional Topics | 1 | 1/11/09 4:11 PM |
| What's this video worth? | jtedesco1 | Inspection Education & Training | 5 | 4/18/08 10:24 AM |
| Radon mitigation exhaust | sfalvey | General Inspection Discussion | 10 | 2/21/06 3:18 PM |
