| IAC2 Indoor Air Forum This forum is hosted by InterNACHI for members of the International Association of Certified Indoor Air Consultants. |
I have been requested to test for radon in a duplex property. The client is only purchasing one side of the property. I do not think this would be vailid test, if I do not test the other side. Any thoughts on this????
Thanks!! Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
| Need a home inspection in Iowa? Check out InterNACHI's listing of Iowa certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Why would it not be a valid test? A duplex is home that shares a common wall with another home. Do the test.
Mark,
I just found my answer in the AARST protocol for radon measurement in multi-family buildings. It says test all units. Thanks! Mid America Property Inspections, Inc. Shawnee, KS 66217 www.mapii.com NACHI # 05110992 KHIRB # 0110-0008 KS-Radon Cert.# KS-MS-0035 KS-Termite Cert. # 18933 M0-Termite Cert. # N 5033 |
The only way I see it as not valid is if there is not an actual separation in the basement with a hard wall. I have seen some where the basement is just divided by a row of studs and chicken wire. So then I would say not valid. but if you have a permanent divider, why not?
In most cases you can't test all units. Therefore you test what you can. Practically speaking, saying you can't test one because you can't test all, is like saying you can't test in one part of the basement because you can't test all.
Again I say, do the test. The EPA recommend that ALL homes be tested during a real estate transaction and every two years after. Not some, ALL. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
You are testing one residence for one client, and they are living in one unit only. Do the test, and recommend future tests at regular intervals, or a long-term test.
Wendell F. Cook, CMI
271 Washington Blvd. Hudson, NY 12534 518-828-0191 www.homeinspectionshudson.com wfchomeinspections@verizon.net Instructor, C.A.T.S. of Albany Home Inspection School "Life is what happens to you while you're busy making other plans." John Lennon |
Thanks!! for the input. I set the monitor on Monday.
| Radon Testing Kansas City | dmoriconi | Ancillary Inspection Services & Additional Topics | 1 | 1/11/09 3:11 PM |
| Radon Class in Oakville and Ottawa | mkyriacou | Canadian Inspectors | 9 | 2/2/08 11:48 PM |
| Ottawa to stiffen radon guidelines. | gromicko | Canadian Inspectors | 1 | 8/16/06 5:28 AM |
