| IAC2 Indoor Air Forum This forum is hosted by InterNACHI for members of the International Association of Certified Indoor Air Consultants. |
| Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
This clearly exceeds the SOP does it not? Are you suggesting this as an addittional inspection for an addittional fee or as a part of a normal inspection?
A general home inspection is one particular type of inspection with its own particular SOP. Most inspections are not home inspections.
Nick Gromicko, Certified Master Inspector Find a Home Inspector "Just as iron sharpens iron, one man sharpens another." Proverbs 27:17 Last edited by gromicko; 10/20/10 at 12:15 AM.. |
Nick we need a TV episode for this one.
ARE WE KIDDING HERE?
It would have been more useful if the author included when (if any) year this device came into widespread use and if it is a building code requirement and where. This is from the article: Spill Switch Testing Spill switches should be tested periodically. Remember to provide adequate ventilation while testing, or CO vapors might become overwhelming and cause personal injury. To do this, first turn off the appliance (we dont do this). Then, remove the vent from the flue and block the vent with sheet metal, plywood, rags or some other material (we dont do this). Turn the appliance on and wait; the switch should trip within 10 minutes, according to the American National Standards Institute, although many manufacturers have shorter time requirements. The switch should be replaced if it doesn’t open within the time specified by the manufacturer (where do we find this information??). To reset the switch, press the button between the switch’s wires. Spill Switch Inspection InterNACHI inspectors can test for the following spill switch defects:
For the third - you get that info from the manufacturer 4th - If it was removed, this is a defect. I'm going to tweek the article's lanuage 5th - I'll add some language about cost effectiveness Researcher and Technical Writer, InterNACHI |
| InterNACHI Update | kshepard | Miscellaneous Discussion for Inspectors | 22 | 1/27/07 10:30 AM |
