| Commercial Inspections Contains discussions about commercial inspections and the International Standards of Practice for Inspecting Commercial Properties. |
Anyone have any resources, docs, books, manuals, or anything on or about chillers they could refer me to? Mostly interested in inspection of, pm's on, and dating of chillers.
| Need a home inspection in Nebraska? Check out InterNACHI's listing of Nebraska certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Cooling towers very important as they can indicate the condition of the tubes within the condenser. Does the tower have auto acid feed to maintain PH levels is the addition of chemicals into the tower maintained in a log book is there a contract with a chemical company to automatic deliver chemicals on site. I would physically observe all safety switches for jumpers there should be none. I would observe the oil level within the sump and note the load on the compressor as this will effect the oil level. I would note the outside ambient at the time of inspection, the return and supply chill water temp the condenser supply and return water temp My best advice if you are not familiar with chill water systems sub it out The Pic is a 1200 ton chiller Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Erol Kartal is a non-member guest and is in no way affiliated with InterNACHI or its members.
I've been in the commercial HVAC business for 20 years and there is no way a building inspector can perform a proper PM on a chiller system unless you have extensive training and experience. Sub it out.
Erol I don't know what Robert's background is so I was just providing enough information to let him know nicely he was probably over his head.
Charley,
Thanks for that post - when I am recommending additional specialist inspections, it's very helpful to be able to explain briefly to the client WHY I am doing so, for example to be able briefly outline what sorts of additional investigations will be performed. |
I just don't want to see an inspector get into trouble by using the phrase 'preventative maintenance' or 'PM' in a report. As we know, there is huge difference between performing a visual inspection and a service that is designed to maintain peak operating performance of equipment. |
I still have several of my centrifical tear down manuals but they are all 6" thick 3 ring binders. Even with my knowledge and experiance I would sub out this portion of the inpsection.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Not me Bruce I don't sub them out a commercial client is not interested in how to tear a chiller down. Basic concern is does it operate and am I going to have to replace it soon, how much past maintenance. Bean counters are interested in the bottom line$
Good info thanks. and im not interested in doing pm's just check to see if they have been done. And the jumper thing thanks for the heads up.
| Chillers | mboyett | Inspecting HVAC Systems | 5 | 8/13/07 8:10 PM |
