Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Commercial Inspections
Commercial Inspections Contains discussions about commercial inspections and the International Standards of Practice for Inspecting Commercial Properties.
Old 4/7/10, 6:50 PM
Nick Gromicko's Avatar
Nick Gromicko Nick Gromicko is online now
Default Detecting Corrosion in Steel Encased in Concrete.
Find a Home Inspector
Need a home inspection in Kansas? Check out InterNACHI's listing of Kansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/7/10, 8:46 PM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
Default Re: Detecting Corrosion in Steel Encased in Concrete.
Change the title to Detecting Corrosion in Concrete Encased Steel. There are to many "in's" in the title and it does not read well.
Old 4/8/10, 11:39 AM
Kate Tarasenko's Avatar
Kate Tarasenko Kate Tarasenko is offline
Thanks, Scott!
Cheers,
Kate
Crimea River
Editor-in-Chief
kate@internachi.org
Old 4/8/10, 11:46 AM
Done.
Old 4/8/10, 1:14 PM
Bob Elliott's Avatar
Interesting article ,but I must admit that I am left feeling a little lost.
I was just taught how PH levels of the encasing concrete effect the steel rebar lifespan but have been left with a wondering as to how it can apply to Home Inspection or Commercial Inspection for that matter.
Does this new knowledge apply in any way to Foundations,lintels,retaining walls,etc.?
A extra paragraph or two on how we can use this article to benefit our client would help.
My impression from reading this is to gloss over and forget, by delegating this to Structural Engineer territory.
Would love to see a few good illustrations to keep focus also.
Old 4/8/10, 1:39 PM
Jeffrey R. Jonas's Avatar
Bob, (I hope you're sitting down)...
Good post. I actually 'got' what you were trying to say for once. I agree with you 100% !!!
Jeff
Old 4/8/10, 2:19 PM
Doug Edwards's Avatar
Rusting metal, be it rebar, lintels, etc. expands as it oxidizes often causing the concrete it is encased causing it to spall or pop off the facing of the concrete. Here are a couple of examples on a beach front I did some years ago. I have also seen some metal lintels that have separated the bricks on either side of the garage door or windows do the same thing and open mortar joints.
- John Stuart Mill
Old 4/8/10, 2:57 PM
Jeff
Funny ,guy.
Old 4/8/10, 3:02 PM
Originally Posted by dedwards View Post
Rusting metal, be it rebar, lintels, etc. expands as it oxidizes often causing the concrete it is encased causing it to spalt or pop off the facing of the concrete. Here are a couple of examples on a beach front I did some years ago. I have also seen some metal lintels that have separated the bricks on either side of the garage door or windows do the same thing and open mortar joints.
Yeah,I think we all see that at times Doug,but how would that relate to concrete with a parge coat over Lintels,or foundations ,where we actually Inspect.?
I often see and have pics somewhere of rebars rusting out through concrete, but just notate and move on.
Old 6/30/11, 3:43 AM
Muhammad Fawad Baig Muhammad Fawad Baig is offline
Please Note: Muhammad Fawad Baig is a non-member guest and is in no way affiliated with InterNACHI or its members.
for complete article visit www.enggpedia.com
The basic problem in Reinforced concrete structures is the corrosion of steel reinforcement. The main cause of this corrosion is intrusion of water inside the RC structures. The corrosion of steel reinforcement can be judged by peculiar cracking of concrete structures.
At last stage of corrosion, the steel reinforcement becomes exposed and the extent of corrosion can be seen as rust.
Corrosion of steel reinforcement usually occurs more in externally located RC members as compared to internally located RC members.
__________________________________________________ ________________________
www.daenotes.com
Post tension slab labeling rchorey Structural Inspections 34 7/6/08 11:43 PM
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
Steel post question sspradling Structural Inspections 42 3/2/07 8:59 PM
