| Commercial Inspections Contains discussions about commercial inspections and the International Standards of Practice for Inspecting Commercial Properties. |
Does anybody know what the life expectancy for a 60 mil black EPDM roof is in the southwest? Or even what the warantee for this type of roof is?
| Need a home inspection in Maine? Check out InterNACHI's listing of Maine certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
most commercial roofs will have a warranty from the manufacturer, depends on the application. the contractor can purchase a 10-15-or 20 year warranty they should be paperwork on the roof if that was done. as to life expectancy also depends on application. what is covering the membrane ? is it coated or ballast, is it glued or fastened
Kisers Home Inspections http://www.inspectorpages.com/jkiser http://activerain.com/jimekiser http://www.kisershomeinspections.com |
There is no coating, just the black EPDM mebrane at the surface. It appears to be fastend at the edges of the sheets with screws that are then covered by EPDM tape (there are 2" dia. dipmples every 12-18" along the edges of each sheet) and it feels like poly insulation wedges for drainage underneath. Our climate is very dry and hot, and I worry about the black rubber exposed to direct sunlight. The surface is oxidized and rubs off on my fingers, the edges of seams are brittle and cracking in some areas.
The membrane should be covered either with gravel, coating, or cap sheet but most of the time that's not done.with that being said there probably is no manufacture warranty on the roof. IMO about 10-15 years as is.
Try this link about epdm.
Drew Levy NJ# 24GI00101400 Radon # MET12929 Homespect LLC (609) 668-7588 http://www.homespectllc.com http://www.philadelphiahomeinspection.net http://www.southjerseycommercialinspection.com http://www.haddonfieldhomeinspection.com http://www.abseconhomeinspection.com http://www.willingborohomeinspector.com http://www.thehomeinspectioninstitute.com |
I have a question:
I was always taught the proper slope for a rubber roof is 1/8" to 2" drop per foot, depending on the manufacturer. Does anybody here know for sure? |
| EPDM Question | mkiss1 | Commercial Inspections | 2 | 6/11/09 10:41 AM |
| Ripples in Rubber Roofing? | jberthiaume | Exterior Inspections | 15 | 6/23/08 10:34 PM |
| Epdm? | mnicholet | Exterior Inspections | 3 | 6/12/08 8:41 PM |
| Making Sense of Single-Ply Roofing | mcyr | Structural Inspections | 0 | 12/22/07 7:36 PM |
| Basement Waterproofing basics | mcyr | General Inspection Discussion | 8 | 8/28/07 5:53 AM |
