| Commercial Inspections Contains discussions about commercial inspections and the International Standards of Practice for Inspecting Commercial Properties. |
I have looked a alot of different systems but have never seen this style. The membrane was not rubber but instead a weaved thin plastic similar to lumber wrap. Has anyone seen this and what is the service life of a roof like this??
Greg Mathias, CCHI Journeyman Carpenter Global Property Inspections Lloydminster, AB. Canada (780)205-9912 |
| Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
imo from photos ballast applied tpo
http://www.nrc-cnrc.gc.ca/eng/ibp/ir.../ctus-n30.html termination at drains is wrong, you probably caught that ;~)) ADAIR INSPECTION 972-487-5634 Commercial-Residential-Construction-EIFS-Infrared Thermography TREC # 4563 EDI: EIFS-MA TX # 39 2008 US Member of the Year life is the random lottery of events followed by numerous narrow escapes accept the good |
That looks like it...but, man, Greg has his work cut out for him removing the balast to inspect it, eh? From above site: Quote:
The only thing bothering me still is that the seams are not welded but overlapped. Wondering if the membrane is only being used as protection and there is a membrane under the foam. It did look like plastic was layed down under the foam?? Roof is 24 years old but seems to be in great condition.
Man, that looks like synthetic underlayment to me, not meant for this application but for sloped roofs and the manufacturers usually list specific overlap requirements for low-slope. This is not even low-slope but basically flat.
Here are some photos of synthetic underlayment for comparison. Evaluation by a qualified roofing contractor. Kenton Shepard, InterNACHI member # 04082383 Certified Master Inspector (CMI) InterNACHI Director of International Development Director of Green Building EXPERT WITNESS SERVICE Conventional and Log homes (303) 717-8940
Any thoughts?? Greg Mathias, CCHI Journeyman Carpenter Global Property Inspections Lloydminster, AB. Canada (780)205-9912 |
It's beyond my level of expertise, I specialize in steep-slope roofing materials.
Ask Dale Duffy
"Be Proud of Your Home, Go With Pride!" 'Not just a Home Inspection, but an Education' Pride Property Inspections provides professional Home Inspections throughout Tucson and Southern Arizona including Pima, Cochise, Pinal, Santa Cruz, Graham counties. |
I would but not sure who that is and could not find him on the forum??
What do you think about it?
Your the one working at an engineering firm... "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
I think he's "undercover CMI"!
I'm totally convinced that that roof is sort of granular.
| Flat roof question | rchorey | Exterior Inspections | 24 | 12/18/07 6:26 PM |
| Roof question | mashburn | Exterior Inspections | 23 | 12/16/07 7:14 PM |
