I am after inspection standards for gas fireplaces and all the related components.
Thank you,
Chip
Thank you,
Chip
Does it ignite.
Does the gas leak.
If a damper, does it work?
Is the firebox in good condition?
Is there a gas shutoff W/I 6 feet?
If glass front, is it clean?
Is the gas line installed on sharp edges of the firebox?
Now, on to the dining room.
I. The inspector shall inspect:
[LIST=A]
[li]and describe the fireplace;[/li][li]and open and close the damper door, if readily accessible and operable;[/li][li]hearth extensions and other permanently installed components;[/li][li]and report as in need of repair deficiencies in the lintel, hearth and material surrounding the fireplace, including the fireplace opening’s clearance from visible combustible materials.[/li][/LIST]
From International Standards of Practice for Performing a General Home Inspection - InterNACHI http://www.nachi.org/sop.htm#ixzz1x3ArrwX3
Do you note discolored/darkened cladding above direct vent exhaust or if the propane bottle is less than 10 feet away from the direct vent exhaust?
I certainly would.
Would recommend they consult with the propane provider.
No source of ignition can be within 10 feet according to here. I would still just make a note that AHJ has the final say to decide.
