Go Back   InterNACHI Inspection Forum > Specific Inspection Topics > Commercial Inspections
Commercial Inspections Contains discussions about commercial inspections and the International Standards of Practice for Inspecting Commercial Properties.
Old 9/25/11, 12:34 PM
Jordan Cooke Jordan Cooke is offline
Please Note: Jordan Cooke is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default OBC Question
Hey guys,
I'm currently a student at Algonquin College in the Architectural Technology program. For a project we have to design a building under Part 9 conditions of the OBC. Our building will consist of two occupancies; residential and restaurant.
In order to keep the restaurant under Part 9 standards we are limited to 30 seats, which is not enough.
So my question is, if we place the restaurant under part 3 standards, how does that affect the Part 9 residential? Will the building still be considered Part 9?
Need a home inspection in Tennessee? Check out InterNACHI's listing of Tennessee certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 9/25/11, 10:53 PM
Marcel Gratton's Avatar
Default Re: OBC Question
Originally Posted by Jordan Cooke View Post
Hey guys,
Your question should be directed to a Building Code Official within your jurisdiction.
On The Level Inspection
Gatineau, Québec
Old 9/26/11, 9:52 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
Marcel is right on this issue. I would not hold your breath on this one you most likely will not get an answer from the MB. This is OBC territory only.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 9/26/11, 11:14 PM
gmoore7 gmoore7 is offline
Please Note: gmoore7 is a non-member guest and is in no way affiliated with InterNACHI or its members.
You need to refer to Div B, 1.2.1.4.(1). which describes a part 9 building. it does not allow an A2 assembly occupancy within part 9 regardless of the size. Once you go over 30 seats in a restaurant it becomes an A2 assembly occupancy.
Since it is all within one building the entire building would need to conform with Part 3 of the OBC.
Old 9/27/11, 5:50 AM
KEVIN WOOD's Avatar
Since no one can answer you you!
Group c d e f all apply to part 9.
not exceeding 600 m2 according to OBC.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 3/5/12, 7:08 AM
Roger A. Frost's Avatar
Roger A. Frost Roger A. Frost is offline
hello Jordan,
I am sure you found your answer but if not. If you have a fire separation ( 2 hour I believe for restaurant over 30 seats ) then your building will be Part 3, If you have a fire wall between occupancies then you can have residential under Part 9. It would be considered a separate building.
Roger Frost CBCO
Barrie Home Inspector
Alliston Home Inspections
Orillia House Inspector
Barrie, ON
(705)795-8255
Sump Pit/Pump Question Joey D'Adamo Plumbing Inspections 4 11/26/08 1:04 PM
Question for all... Bob Hopton-Jones General Inspection Discussion 9 4/6/07 7:43 AM
Basement Bathroom Venting Question Sean M. Jeric Plumbing Inspections 4 3/20/07 11:56 PM
