| Commercial Inspections Contains discussions about commercial inspections and the International Standards of Practice for Inspecting Commercial Properties. |
I have a client with a commercial refrigeration room. Above the ceiling in the room is an empty space approx 4' high. One wall(cinder block) of this empty space has a boiler room on the other side. The boiler room is very warm at all times. There is condensation building up in the empty space, I suspect because of heat transfer through the concrete block wall. The condensation has been excessive enough to cause the insulated ceiling to get saturated and buckle. My question is:
Which side of the concrete block wall should be insulated? warm side or cold side? Comments please. Rodney Misener, CMI Trinity Inspection Services Pictou County, Nova Scotia http://www.trinityinspectionservices.com Certified Master Inspector Certified Level 1 Thermographer Certified Energy Advisor WETT eCertified Inspector IAC2 Radon/Mold Certified Infrared Certified |
Insulation does not stop moisture infiltration.
Heat does not cause condensation. The ceiling should be insulated. There should be enough insulation so the exterior does not drop down below the dew point temp. This will stop condensation. Air infiltration (which contains the moisture) should be controlled if possible. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| Light switch where entering a room. | mgault | Electrical Inspections | 19 | 11/17/07 8:00 AM |
| Report Writing: Room by Room or System by System by Dr. Keith Swift | gromicko | Miscellaneous Discussion for Inspectors | 0 | 6/5/06 1:10 PM |
| Exhaust fan in room with gas water heater and furnace | jweinberg | Inspecting HVAC Systems | 7 | 2/18/06 1:23 PM |
