AskNACHI.org » ADA compliance expert home inspectors (posted by Elizabeth Mendez)
Old 5/9/07, 12:15 PM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default ADA compliance expert home inspectors (posted by Elizabeth Mendez)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Elizabeth Mendez[/B] (from Arlington, VA). [/ASKNACHI]To Whom It May Concern:
I am trying to locate a home inspector in the Arlington, VA area that specializes on ADA compliance issues. I\'m in the process of purchasing a condominium that has been classified by the builder/developer as \"ADA compliant\". I would like to hire a home inspector for my walk-thru that is well-versed in the building requirements for ADA compliant dwellings.
Elizabeth Mendez
Old 5/9/07, 3:32 PM
afrost afrost is offline
Please Note: afrost is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: ADA compliance expert home inspectors (posted by Elizabeth Mendez)
[COLOR=black][FONT=Verdana]ADA[/FONT][/COLOR][COLOR=black][FONT=Verdana] is a set of regulations about designing for the disabled. Typically it concerns access so designs often incorporate ramps with handrails (the ramps are a certain pitch and the rails a certain dimension off the ground), with door openings wide enough for wheelchairs, shower stalls accessible by wheelchair, sinks that a wheelchair can slide under (with protection from the hot water pipes), chair lifts or sometimes LULA elevators, etc.[/FONT][/COLOR]
[COLOR=black][FONT=Verdana] [/FONT][/COLOR]
[COLOR=black][FONT=Verdana]As you have probably found out, most of this is beyond the purview of a Home Inspector. [COLOR=black][FONT=Verdana]Typically Home Inspectors are not "Code Inspectors". [/FONT][/COLOR][/FONT][/COLOR]
[COLOR=black][FONT=Verdana]Assuming that the builder/developer had an Architect in order to get a building Permit, you should talk to the Architect and use them as a resource. Ask what standards he used. In commercial construction there is a set of Federal Regulations. I am not sure if there are regulations for residential design. If there are none, then it is difficult to inspect because there is no benchmark to measure against.[/FONT][/COLOR]
[COLOR=black][FONT=Verdana]Another resource may be any public organizations that specializes in the particular disability that you want considered in the design. It may not be wheelchair access, it may be a sight or visual disability.[/FONT][/COLOR]
[COLOR=black][FONT=Verdana]Here is a link to the Federal ADA Regulations and additional ADA information [URL="http://www.usdoj.gov/crt/ada/adahom1.htm"]http://www.usdoj.gov/crt/ada/adahom1.htm[/URL]. [/FONT][/COLOR][COLOR=black][FONT=Verdana]Massachusetts[/FONT][/COLOR][COLOR=black][FONT=Verdana] has their own version, perhaps [/FONT][/COLOR][COLOR=black][FONT=Verdana]Virginia[/FONT][/COLOR][COLOR=black][FONT=Verdana] does, too, & you can contact the state.[/FONT][/COLOR]
[COLOR=black][FONT=Verdana]If you were willing to define the [/FONT][/COLOR][COLOR=black][FONT=Verdana]ADA[/FONT][/COLOR][COLOR=black][FONT=Verdana] design requirements you want from the Condo, you can begin to discuss your needs with some Home Inspectors and will find one that would love to help.[/FONT][/COLOR]
[COLOR=black][FONT=Verdana]Good Luck.[/FONT][/COLOR]
[COLOR=black][FONT=Verdana][/FONT][/COLOR]
[COLOR=black][FONT=Verdana]Andy Frost[/FONT][/COLOR]
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
