Can a different type of insulation be placed over an existing fiberglass insulation, already in place? I have only 12 inches of fiberglass insulation in my attic. A contractor said that I needed to place additional insulation to bring that up to 20 inches. Another contractor said that I could use cellulose over the fiberglass.
Question is? Is there any reason you can't use a different type of insulation on top of the existing, such as cellulose? Or would I be best to keep consistent, and use the fiberglass insulation? Is weight a factor? Do I REALLY NEED 20 inches of insulation. I live in hot north central Texas. Fiberglass seems to cost more, so cost is a factor as well. But, I also am concerned about cellulose becoming a fire hazzard. What are my best alternatives here? THANKs. Gerri Williams |
| Find an InterNACHI certified Rhode Island Home Inspector (and anywhere else in North America) |
Dbl post
Adding different insulation on top is okay.
Cellulose, typically, has a flame retardant added. It closes off gaps better that batts, IMO. Here are some links to help you decide but adding anothe 8 inches of cellulose on top of 12" of batts may be a little much. Recommended levels of insulation: http://www.energystar.gov/index.cfm?c=home_sealing.hm_improvement_insulation_table Adding insulation to an existing home: http://www.energysavers.gov/your_home/insulation_airsealing/index.cfm/mytopic=11350 http://www.ornl.gov/sci/roofs+walls/insulation/ins_06.html Estimating the payback of adding insulation: http://www.energysavers.gov/your_home/insulation_airsealing/index.cfm/mytopic=11360 InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
I see different insulations all the time. No problem.
I did a commercial building some time back that had 3 different types of insulation. They built out the building in 4 different stages. The first 3 attic areas each had a different type of insulation (probably whatever was cheapest at the time of buildout). The 4th attic area had a mixture of the leftovers of the first 3. Mark Nahrgang www.DaytonSpringfieldHomeInspector.com www.HeyMark.info Home Inspections for Springfield, Dayton, and surrounding OH areas. |
