AskNACHI.org » Attic Rafter Span
Old 5/12/10, 7:47 AM
Unregistered
Guest
Posts: n/a
Default Attic Rafter Span
Hello, I'm wondering if someone can tell me if a home inspector should know attic rafter spans. We have a stick built attic with 2 x 6 attic rafters which hold up the roof. Every contractor tells us the rafters need to be 2 x 8 to carry the load of the roof. Even the center ridge beam is 2 x 6.
In addition the floor plan below ie: the ceiling of the rooms is an open floor plan with rooms as big as 16 feet. We are being told by contractors that the beams which hold up the ceiling needs to be at least 2 x 8 because the span underneath is 16 feet.
Should a home inspector who walked the attic know to look for span issues?
Thank you for your help.
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 5/12/10, 8:01 PM
Sean Fogarty's Avatar
Default Re: Attic Rafter Span
The home inspector does not measure and evaluate loads or spans when inspecting. I personaly make a note if I notice an obvious issue or problem, but to many factors exist to make that call. When was the home built? Where is the home?
The structure does not need to be as strong when no load is expected. Your question can only be answered by an engeneering examination, not by a contractor. The house should have been designed with blueprints and all those factors were calculated when the plans were drawn up.
Also most standard maufatured trusses are 2x4's so that kind of shoots down the idea of 2x6's not being strong enough in some repsects. Rafters are capable of spanning a certain length depending on the size, the bigger they are the longer they can span.
I would say if the home is no more than 50 years and everything looks satisfactory then there should be no problem. If you are concerned additional bracing can always be added, but you can't blame the inspector for not doing somthing they are not required to do.
865-256-5397
www.moldandradon.com
www.thermal-inspection.net
Old 5/12/10, 9:12 PM
Mario A. Kyriacou, CHI's Avatar
Mario A. Kyriacou, CHI Mario A. Kyriacou, CHI is offline
ESOP Committee Member
Many items have to be taken into consideration including loads, roof pitch etc. Dwarf walls, collar ties etc. are also used to construct roofs. I don't know the area in which you reside but It sounds to me that you are at the limit of allowable span. Can you provide additional information? Type of roof, snow load etc.
BTW It has been my experience that contractors know current code.
'Imagination is more important than knowledge' (sometimes)
Mario Kyriacou CHI CMI-NACHI Canadian Member of the Year 2007
www.360degreeshomeinspections.com
Tel.# 416-722-6132
e-mail torontohomeinspector@yahoo.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
