AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Bill Sims[/B] (from Valley, Al). [/ASKNACHI] House has a utility meter with ground rod common to neutral. 3 wire service ran to main disconnect panel on other side of house. A separate EG ground rod with #4 Bare running from rod to EG Bar. Neutral is not bonded.
Should neutral and EG be bonded in this panel since there are 2 separate ground rods. |
Yes,
The neutral and ground should be bonded in the panel that has the first point of disconnect. The ground rod at the meter is all that is needed. The other one is installed incorrectly. B.A. King Home Inspections, LLC www.BAKingHomeInspections.com Serving Charlotte NC area and Rock Hill SC areas. CMI Certified Master Inspector and Independent License NC2449 and SC1597 704 301-3207 "Discovery consists in seeing what everyone else has seen and thinking what no one else has thought." - Albert Szent-Gyvrgyi, Nobel Prize for Medicine 1937 |
You know....I have been doing this MANY years and I totally can't understand what was just asked...lol.....and I do this for a living.
If the meter has a Grounding Electrode Conductor coming out of it to the ground rods...then that portion of the grounding electrode system is complete. Now, what is confusing is you said a main disconnect was all the way on the other side of the house........ So is their a disconnect at the meter or did they just run the service cable all the way around the house( hopefully not under to through the house in violation of 230.70(A)(1)....) Anyway.....Yes you bond the grounded and grounding at the main service disconnect...At a remote distribution panel you do not...the grounded conductor is insulated from the enclosure. Paul W. Abernathy |
[quote=pabernathy]You know....I have been doing this MANY years and I totally can't understand what was just asked...lol.....and I do this for a living.
If the meter has a Grounding Electrode Conductor coming out of it to the ground rods...then that portion of the grounding electrode system is complete. Now, what is confusing is you said a main disconnect was all the way on the other side of the house........ So is their a disconnect at the meter or did they just run the service cable all the way around the house( hopefully not under to through the house in violation of 230.70(A)(1)....) Anyway.....Yes you bond the grounded and grounding at the main service disconnect...At a remote distribution panel you do not...the grounded conductor is insulated from the enclosure.[/quote]Well Paul for not understanding it, you explained it pretty well. ;-) I think.....lol Christopher Currins Certified, Licensed Proudly serving the St.Louis Metro St. Charles, St. Peters, Maryland Heights, O'Fallon, Florrisant, MO Home Inspector BLESSED ARE THE CRACKED, FOR THEY ARE THE ONES WHO LET IN THE "LIGHT"!
He simply said that the other panel is a sub-panel. (old terminology)
I think the question related to at what point is it not a sub-panel. I know that a garage or seperate structure gets it's own ground, but at what point is it ever needed in the same structure? |
[quote=relliott]He simply said that the other panel is a sub-panel. (old terminology)
[/quote] Sorry......I did not get the SIMPLY part of the format of the question...but then again what do I know...lol Paul W. Abernathy |
