AskNACHI.org » Building Code NFPA211 -- Fuel Oil Code 4.2.2.8
Old 9/2/11, 9:06 AM
Unregistered
Guest
Posts: n/a
Default Building Code NFPA211 -- Fuel Oil Code 4.2.2.8
Building Code NFPA211 --- Fuel Oil Code 4.2.2.8
Dear Sirs. / Ms
We have been requested to agree that an installation passes Fuel Oil Code 4.2.2.8 and Building Code NFPA211
Data that can be found is 4.2.2 ---- but not with the added 8.--- we would appreciate being advised on the missing link.
Thanking you on anticipation ---- _____ Cliff. (Clifford G. Kerr ... P. Eng.)
Old 9/2/11, 9:43 AM
Default Re: Building Code NFPA211 -- Fuel Oil Code 4.2.2.8
It would seem that the details would be narrowed down by the job specifications but here is a quick GOOGLE search:
4.2.2.8 Automobile And Light Duty Truck Surface Coating Operations
http://www.epa.gov/ttnchie1/ap42/toc_kwrd.pdf (copy and paste into your browser window)
and
NFPA 211: STANDARD FOR CHIMNEYS, FIREPLACES, VENTS, AND SOLID FUEL-BURNING APPLIANCES
http://www.nfpa.org/catalog/product.asp?pid=21110&order%5Fsrc=B484 (copy and paste into your browser window)
Larry Kage, CMI
231 929 3525
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
