AskNACHI.org » certification as a well water tester. (posted by Mike Kinney)
Old 10/12/07, 12:56 PM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default certification as a well water tester. (posted by Mike Kinney)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Mike Kinney[/B] (from Dayton, TN). [/ASKNACHI]I am a swimming pool chemical store owner and test water for pools. I would like to be certified to test drinking water from wells and provide that service to realestate agents in the area. The realestate agents currently use home inspectors and my question is, can I get certified in a specific home inspection category like well water. If so, what are the specific certifications that I would need and where can I find the information?
Old 10/12/07, 7:34 PM
James H. Bushart's Avatar
Default Re: certification as a well water tester. (posted by Mike Kinney)
[quote=AskNACHI.org][asknachi]This question was posted on [I]AskNACHI.org[/I] by [B]Mike Kinney[/B] (from Dayton, TN). [/asknachi]I am a swimming pool chemical store owner and test water for pools. I would like to be certified to test drinking water from wells and provide that service to realestate agents in the area. The realestate agents currently use home inspectors and my question is, can I get certified in a specific home inspection category like well water. If so, what are the specific certifications that I would need and where can I find the information?[/quote]
To my knowledge, the only well water certification class that is presently available is provided by Joe Farsetta. The course is available on CD as well as classroom.
Perhaps Joe can elaborate on what one must do to obtain access to either of these.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
Old 10/12/07, 8:10 PM
Mark R. Long's Avatar
Mark R. Long Mark R. Long is offline
I too used to own a swimming pool store and tested water for pools. I believe that testing drinking water, especially for a real estate transaction, is a slightly different animal. If you're talking about actually doing the testing, I believe you would have to be a lab certified by your state. You should probably check with your state.
If you are talking about just [B][I]drawing[/I][/B] the water and taking it to a lab, then you may or may not have to be certified depending on your state's/locale's requirements.
I happen to live on the PA/MD border. I can draw water in PA for a real estate transaction and take it to a lab without any certification. In MD I must be certified just to draw the water. Just coincidentally, I'm taking a half day class in two weeks at the adjoining county Health Dept. in order to get my MD certification. I hadn't gotten around to doing this before now.
Where I haven't been able to draw water, I have been able to get a local lab to come to the location, draw the water and have it tested for a standard bacterial analysis for $21. I'm not sure how you would be able to make this profitable if you aren't a full scale lab or doing it in conjunction with inspections.
Mark
MD HI Lic # 30090
BPI Certified Building Analyst
PA DEP Radon Cert # 2457
Certified Home Energy Tune-uP Inspector
Old 10/12/07, 11:17 PM
dbush's Avatar
dbush dbush is offline
Send a message via MSN to dbush Send a message via Yahoo to dbush
Please Note: dbush is a non-member guest and is in no way affiliated with InterNACHI or its members.
In Missouri, the certification is done as part of the Septic Inspector Course or through the Department of Natural Resources. You might check with the equivalent of those in Tennessee.
Old 10/13/07, 6:40 AM
[quote=dbush]In Missouri, the certification is done as part of the Septic Inspector Course or through the Department of Natural Resources. You might check with the equivalent of those in Tennessee.[/quote]
In Missouri, only those doing Septic Inspections require certification in this area. There are no requirements for collecting water samples outside of a septic inspection.
James H. Bushart
314-803-2167
Old 10/13/07, 8:16 PM
Joe Farsetta's Avatar
Joe Farsetta Joe Farsetta is offline
ESOP Committee Member
Dave,
Jim is correct on this one. I was asked to submit my course to the DNR las year and consider teaching it at the farm to septic inspectors. I never got around to it.
Jim, would consider looking into this (again ) for me and perhaps forwarding the data to them. I'll give it to you next week at the Commercial Course...
As to the question from our asker from Tennessee... Certified Well Sampler is approved in that state, and in Mississippi, for continuing education credits for HIs
Old 10/14/07, 3:47 PM
dbush's Avatar
Jim and Joe, that is probably true. I went through the Septic Inspector Course and it included the Water Certification which is required to process the "official" results through the Health Department Lab. They will do an unofficial result, but they require certification of training, which Joe, I believe your course meets that requirement.
Old 10/15/07, 7:59 AM
Thanks, Dave
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
