AskNACHI.org » to certify or not to certify (posted by Joseph Biddle)
Old 8/5/08, 8:26 PM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default to certify or not to certify (posted by Joseph Biddle)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Joseph Biddle[/B] (from Austin, Texas). [/ASKNACHI]what are your opinions on how to "certify" a home with an old a/c (18 years old) that is cooling too high (27 degrees)?
Is is to certify with repairs, certify with repairs including up to possible replacement, or not certify untill operating under normal ranges
Joey Biddle Trec # 4337
Old 8/5/08, 8:32 PM
David A. Andersen's Avatar
Default Re: to certify or not to certify (posted by Joseph Biddle)
Where did you get 27 degrees?
Cooling too high or too low?
Do u mean a "high split"?
You need more than a dry bulb temp split to "certify" anything.
Fill us in a little better.
BPI# 5015804
Old 8/5/08, 8:51 PM
James E. Braun, CMI's Avatar
[quote=AskNACHI.org][asknachi]This question was posted on [I]AskNACHI.org[/I] by [B]Joseph Biddle[/B] (from Austin, Texas). [/asknachi]what are your opinions on how to "certify" a home with an old a/c (18 years old) that is cooling too high (27 degrees)?
Joey Biddle Trec # 4337[/quote]
I am guessing you are talking about the difference between the supply and the return air. Just because it is over 20 degrees does not mean there is a problem. When I owned a heating and cooling company I have seen several over 30 degrees difference and they ran fine. If you feel it is a problem such as an A-coil dirty or blocked, you could refer it to a licensed HVAC technician for further evaluation.
Old 8/5/08, 9:06 PM
James H. Bushart's Avatar
If you have been asked to provide "certification" for your HVAC system (sometimes required by certain municpalities/counties for residency permits), it will be required to have a licensed (or other officially recognized) HVAC specialist provide that certification.
As a building inspector for two municipalities in the St. Louis area, I will often find amateur work done on furnaces, air conditioning units, and ductwork/exhaust without permits during an inspection. I will simply require the owner of the property, prior to issuing an occupancy permit, to provide certification by a licensed HVAC technician that the unit is properly installed and that all of the work meets the present code.
This certification usually costs the homeowner as much, if not more, than what they saved by having their cousin's brother-in-law's nephew do the work....but it provides the city with a bonded professional taking responsibility for the work that was done.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
