AskNACHI.org » Chinese Drywall
Old 10/5/09, 11:59 AM
Clint Roberts
Guest
Posts: n/a
Default Chinese Drywall
Other than looking at the back of the drywall for a label (in the attic) or looking at terminal screws for black discorloration at outlets and switches, is there anyway to be certain about the possibility of the presence of the bad drywall beside destructive testing?
Find an InterNACHI certified Massachusetts Home Inspector (and anywhere else in North America)
Old 10/5/09, 1:03 PM
Bruce A. King's Avatar
Default Re: Chinese Drywall
no, not really, and taking physical samples for testing would technically require a sample from every sheet in the house since more than one shipment could have been delivered to the site during construction.
The A/C coils are another good place to check for discoloration.
www.BAKingHomeInspections.com
704 301-3207
Old 10/6/09, 11:44 PM
Nick Gromicko's Avatar
http://www.nachi.org/chinese-drywall.htm
Find a Home Inspector
Old 10/7/09, 4:52 PM
In addition to what is listed on the INACHI drywall page, the evaporator coil of the air handler should be checked. I found Chinese drywall in a home last week only because I saw the blackened copper fittings on the evaporator coil. Yes, opening the air handler is beyond the scope of a normal visual inspection, but if we're inspecting for indications of the presence of Chinese drywall, it is a must. It turned out that only a few sheets of bad sheetrock had been used in the home, contained at a small area of the kitchen and adjacent foyer and laundry room.
In addition to destructive testing, sheetrock can be checked with an XRF gun (X-ray Fluorescence), which is the same instrument used to properly check for lead. This would be the preferred method, although the guns are very, very expensive and few people have made the considerable investment to purchase one and become properly trained.
Abraham Lincoln
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274
