AskNACHI.org » Clad on hardwood floor to absorb noise
Old 12/27/11, 7:06 PM
Unregistered
Guest
Posts: n/a
Default Clad on hardwood floor to absorb noise
I have a project to reduce noise in museum that has old hardwood floor not to be removed. Surface: 10,500 sq ft.
What would be the best sound-absorbing material to put on that floor with plenty visitors walking on it?
Need a home inspection in Virginia? Check out InterNACHI's listing of Virginia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/27/11, 8:45 PM
Steven C. Waskewicz's Avatar
Steven C. Waskewicz Steven C. Waskewicz is online now
Default Re: Clad on hardwood floor to absorb noise
I would contact a local representative of a flooring company.
Someone that would warranty the job for you professionally.
Steven Waskewicz
Colorado Springs, Colorado
719-510-7703
Rest Assured Inspection Services, LLC.
719-510-7703 mobile all the time
Old 12/27/11, 8:48 PM
Cork flooring
Old 12/28/11, 10:21 AM
Jeffrey R. Jonas's Avatar
Commercial grade carpeting.
Depends what final result they are looking for. Are they indicating they want the hardwood visible?
Need more details.
Old 12/29/11, 10:27 AM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
Both! Carpet for high traffic areas and cork for display areas. This way the carpet acts as a filter and cuts down on dust. The cork flooring reduces noise and increases sustainable appearance, plus if you install the carpet squares that interlock and floating cork then you can change things around easily.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
