AskNACHI.org » code violaton?
Old 7/1/09, 2:57 AM
mommar
Guest
Posts: n/a
Default code violaton?
I had a company install a fixed office system over my hvac unit, now I can not get to shut it off/on. Is this a code violation? Is there a violation of obstruction a vent? Should there be a clearance height?
Find an InterNACHI certified North Dakota Home Inspector (and anywhere else in North America)
Old 7/1/09, 10:40 AM
Bob Elliott's Avatar
Default Re: code violaton?
That is more an electronics question.
I doubt it is a code violation ,but may be a common sense violation if duct is not insulated and gets very hot .
Old 7/1/09, 10:54 AM
James H. Bushart's Avatar
[QUOTE=mommar;531875]I had a company install a fixed office system over my hvac unit, now I can not get to shut it off/on. Is this a code violation? Is there a violation of obstruction a vent? Should there be a clearance height?[/QUOTE]
There is only one way to determine a "code violation" and that is from the only source authorized to make such a determination....the authority having jurisdiction in your particular area.
There are a variety of sources that suggest proper installation and, upon their adoption by cities and counties, modifications can be made by ordinance/law and interpretations can be (at best) inconsistent and (at worse) wrong.
But the AHJ is right even when he is wrong, according to the law...unless overturned by appeal.
Start with your local City Hall and learn what your code book says on the issue...and start from there.
Good luck.
James H. Bushart
Missouri, Kansas and Arkansas
314-803-2167
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
