AskNACHI.org » coiled pex
Old 1/10/10, 11:04 AM
Aprobuilder
Guest
Posts: n/a
Default coiled pex
How does one go about straightening out pex that is in a coil? It seems to me almost impossible. I have a heat blanket that I use on conduit but I'm not sure I can use it.
Need a home inspection in Nevada? Check out InterNACHI's listing of Nevada certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/10/10, 5:50 PM
Default Re: coiled pex
Here is a tool (cut and paste the link into your browser):
http://www.pexsupply.com/PEX-Uncoilers-564000
I'm sure there are some "home made" ideas out there too.
Larry Kage, CMI
231 929 3525
Old 1/10/10, 6:36 PM
Jeffrey R. Jonas's Avatar
Larry,
I suspect by his/her reference to a heat blanket, he/she is looking to "straighten" the coiled PEX, not "uncoil" it.
Sorry, I cannot help with the question, as I have never worked with PEX.
Jeff
Old 1/10/10, 8:36 PM
David P. Valley's Avatar
The aluminum layer in the PEX allows it to hold its shape, much like a pipe cleaner. Standard PEX comes in a coil, and to straighten it and to get it where you want it. It will be easier to remove it and lay it out where you want it and have it stay put.
Old 1/10/10, 8:48 PM
Stephen W. Stanczyk's Avatar
PEX used for water supply does not have aluminum. It is only the special PEX-AL-PEX that contains the aluminum and it is not for potable water.
Even when cold, PEX is easily straightened but if you have a large roll, you need to have something like the "uncoiler" to keep it from looking like a pile of spaghetti.
Stephen Stanczyk
Old 1/10/10, 8:53 PM
[QUOTE=sstanczyk;606691]PEX used for water supply does not have aluminum. It is only the special PEX-AL-PEX that contains the aluminum and it is not for potable water.
Even when cold, PEX is easily straightened but if you have a large roll, you need to have something like the "uncoiler" to keep it from looking like a pile of spaghetti.[/QUOTE]
Where does it say he's using it for potable water supply?
Old 1/10/10, 9:05 PM
If he is using PEX-AL-PEX for a specialty installation like heating or cooling, I don't think a trained installer wouldn't be asking this question. Not at 1/3 again as expensive as regular PEX.
Stephen Stanczyk
Old 1/10/10, 10:11 PM
Joe Funderburk, CMI's Avatar
I installed PEX at my house. Definitely a 2 man job and not an easy one for a non-plumber like me. One has to hold the roll of PEX and the other has to pull the open end. I found it was best to take the open end where you want it, and straighten it has you are working your way back out by securing it with clips to the sub-floor.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
