AskNACHI.org » conflicting roofers (posted by david gannon)
Old 3/3/08, 12:45 PM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default conflicting roofers (posted by david gannon)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]david gannon[/B] (from denver, co). [/ASKNACHI]i have had 3 roofers come out and inspect our roof. all have given me completely different prices and observations.
one said we need an entire new roof down to the rafters ( replace decking and all) ($20K),
one said just new roofing down to the decking, the decking is fine ($8k)
and a third roofer that says he does 400 roofs a year said I do not need a new roof at all.( he said we have another 3-5 years on it) this is exactly what the home inspector said when we bought the house last May.
we need an unbiased inspector. what do we do?
thanks
dave
Old 3/3/08, 1:06 PM
sradabaugh sradabaugh is offline
Default Re: conflicting roofers (posted by david gannon)
[QUOTE]
thanks
dave
[/QUOTE]
Dave,
It sounds as if you already had an unbiased inspector. Your home inspector does not have any financial ties to any of the roofing companies you chose, does he?
Old 3/3/08, 2:08 PM
jbettencourt jbettencourt is offline
Please Note: jbettencourt is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think if you found a roofer that came to look at your roof and told you that you still have 3-5 years on it while he could have qouted you on a job and made some money, you found an honest guy. His findings match that of the inspector, however 3-5 years is an opinion and can vary, also that time can pass quickly. I believe if you are that close and have money in the budget to change it now , find out from the third roofer a price and it might be worthwhile to change now before any leaks or damage to the decking have a chance to occur. Best of Luck.
Old 3/3/08, 6:05 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
[quote=jbettencourt]I think if you found a roofer that came to look at your roof and told you that you still have 3-5 years on it while he could have qouted you on a job and made some money, you found an honest guy. His findings match that of the inspector, however 3-5 years is an opinion and can vary, also that time can pass quickly. I believe if you are that close and have money in the budget to change it now , find out from the third roofer a price and it might be worthwhile to change now before any leaks or damage to the decking have a chance to occur. Best of Luck.[/quote]
I agree with Jerry. The guy didn't try to soak you for any money, just gave you an honest opinion. And that opinion matched that of your inspector, who from what we know has no ties to this. But I guess I would budget for it and replace it BEFORE it loses its effectiveness and starts leaking. If you wait too long it may cost you more in the long run. If you're still worried about it, have some more roofers over, most do quotes for free.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 3/3/08, 9:41 PM
Bruce A. King's Avatar
When you ask a roofer for an opinion or estimate on a roof, you are showing him that you have doubts about that roof. The roofer needs to make money so he obliges you and offers to replace it.
It sounds like it is, in fact, in the last part of its life span.
This age roof is hard to analyze, leaks may or may not show up simply based on the underlayment technique, rain fall amount and wind direction.
Wait till it warms up some, roofers do less damage to the new shingles when they work in warmer weather.
Did the guy that wants to replace the sheathing go in the attic and look at it?
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
