AskNACHI.org » Crawl Space Venting
Old 3/1/09, 5:06 PM
Unregistered
Guest
Posts: n/a
Default Crawl Space Venting
Should crawl spaces have open vents in the warmer months? I live in NC. I am hearing that I should not vent my crawl space in the summer anymore.
Old 3/1/09, 11:56 PM
Bruce A. King's Avatar
Default Re: Crawl Space Venting
NC is in the zone of "good arguments on both sides".
It really depends on the amount of moisture in the ground under the particular house and the quality of the vapor barrier installation. Other important factors include, surface water control, height of framing above the ground, amount of moisture generated inside the living space, size of living space and amount of sunshine/shade on the house.
Its a complicated subject that really just depends on the exact conditions present at your site. Sealed/conditioned crawls are the best and almost all others will have some negative issues at some point during the life of the structure.
www.BAKingHomeInspections.com
License NC2449 and SC1597
704 301-3207
Old 3/2/09, 12:09 PM
Joe Funderburk, CMI's Avatar
Vent it in all but the extreme winter months. Our experience shows that wood moisture and humidity are more of a concern in the summer. Even with all the vents open, stagnant, humid air can contribute to excessive moisture in the wood structures that can lead to expensive repairs. We therefore always recommend visual monitoring of the crawl space at least annually, and especially during the humid summer months. A licensed pest control company can be retained to test the moisture content of the wood using specialized instruments. It should be < 20%. If it's higher, put down a 100% vapor barrier (plastic) on the ground. Test again. You should be aware that wood will decay at moisture levels > 28% and will support fungi growth at levels in the low-20s.
I would not close the vents unless the results I outlined above are poor. If so, you can "condition" the crawl space. That means sealing the floor and walls and blowing conditioned air into the crawl. That can be and expensive undertaking. You may not need to do it. Vent it first and test the wood this summer and see what you get.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 3/2/09, 12:10 PM
Mine is vented and it's been OK for over 100 years.
Theodore Roosevelt
Joe Funderburk, CMI
Old 3/2/09, 12:12 PM
I inspected one house a few years ago. It was about 12 years old and the vents had been closed for quite some time. A large portion of the floor framing was rotted.
Theodore Roosevelt
Joe Funderburk, CMI
Old 3/2/09, 6:19 PM
[QUOTE=jfunderburk;495225]Mine is vented and it's been OK for over 100 years.[/QUOTE]
Most of those 100 years it did not have floor insulation to trap moisture.
Or put another way, the house kept the crawlspace drier due to easy airflow between the two areas.
A vapor barrier is needed way before the wood reaches 20% !
Anything above around 15% indicates elevated and prolonged moisture/humidity in the crawlspace.
704 301-3207
Old 3/2/09, 7:29 PM
[QUOTE=bking;495376]Most of those 100 years it did not have floor insulation to trap moisture.[/QUOTE]
That's true. And, my house sits on top of a hill and water flows away from the house...moisture intrusion is not a problem. I don't even have a vapor barrier...it's dry as Egypt under my house.
Theodore Roosevelt
Joe Funderburk, CMI
Old 3/4/09, 5:17 PM
Unregistered
Guest
Posts: n/a
Thanks guys!
My lot is very steep, and shady. I think I will continue to close vents in the winter, and open them in the warmer months.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
