AskNACHI.org » Damp corner in the basement (posted by Shayne Duquette)
Old 7/8/08, 11:03 AM
AskNACHI.org AskNACHI.org is offline
Automated messenger from AskNACHI.org
Please Note: AskNACHI.org is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Damp corner in the basement (posted by Shayne Duquette)
[ASKNACHI]This question was posted on [I]AskNACHI.org[/I] by [B]Shayne Duquette[/B] (from Timmins). [/ASKNACHI]I've noticed one corner in my basement is damp. I believe water has found it's way in. How do I determine the main cause of this problem? (weepers, improper drainage, cracks, etc. )
Should or can this problem be looked after from the inside of the home vs. the out?
Old 7/8/08, 11:25 AM
Joseph Tribuzio's Avatar
Joseph Tribuzio Joseph Tribuzio is offline
Default Re: Damp corner in the basement (posted by Shayne Duquette)
First look outside, see if that particular corner has a downspout by it, check to see if it is draining at least 5 feet away from the homes foundation. Verify if the ground in that area is slanting towards the house or away from the house. Try that first and we can go from there.
Joseph Tribuzio 708 453 8447
Tribuzio Home Inspection Services
CHICAGOLAND, ILLINOIS
www.thishomeinspector.com
ID# NACHI07062507
IL Lic#450.003128
Radon lic# RNIT2008216
Home Inspector Pro Software
HIP Web Hosting
Old 7/8/08, 11:31 AM
Outside troubleshooting and remedies are often easier and more effective. Inside remedies sometimes include breaking up the floor in the basement and adding a perimeter drain tile routed to a sump pump.
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 7/8/08, 11:34 AM
David A. Andersen's Avatar
Start looking at the ridge of your roof!
"If you ware a drop of rain, where would you go"?
Gutter deficiencies are the most common cause of this moisture intrusion around here.
[SIZE=2]Gutters may not be properly sized and water will overflow/back flow the gutter system and hit the foundation.
Complex roof designs channel water to centralize locations which may not have the capacity.
Gutter downspouts discharge against foundations without proper diversion away from the building.
The elevation difference between the yard and the bottom of your basement is specifically relative to the hydrostatic pressure of that water. It does not matter how much water but how much elevation differential is involved.
Foundation drains which are buried below grade may be leaking at the corner of the foundation. Gutter downspouts are sometimes installed into these drains improperly.
Depending on the age of the house the soil is generally not compacted against the foundation wall because what it is still green and it may be damaged from the soil pressure. It takes several years for the soil to adequately compact and resists moisture infiltration. In the meanwhile we must keep the water away from the foundation/footer.
This settling causes a negative grade against the foundation where windblown rain and gutter overflow land against the foundation and cannot flow away into the yard. The result is water into the crawlspace.
99% of the houses I inspect have these issues (in one respect or another) including new homes.
Before you take remedial action to dry proof your basement, always address the source of the moisture. Often, addressing the source will alleviate the problem entirely.
Concrete (which foundations are constructed of) is not waterproof (even though they make dams from this material).
Under few conditions subterranean water flow and wet weather Springs, to include artesian Springs may also be the source of the water, but these are much less likely of an occurrence.
[/SIZE]
BPI# 5015804
Old 7/8/08, 12:10 PM
Second, get a ladder and some one to stand by while you go up to the gutter and make sure its not clogged with debris. when was the last time it was cleaned out ?, And is there a big tree close by? Is there moisture any where else in your BASEMENT?
ID# NACHI07062507
IL Lic#450.003128
HIP Web Hosting
Old 7/9/08, 12:07 AM
Scott Gilligan,  CMI's Avatar
Scott Gilligan, CMI Scott Gilligan,  CMI is offline
Send a message via AIM to sgilligan1 Send a message via MSN to sgilligan1 Send a message via Yahoo to sgilligan1
[quote=AskNACHI.org][asknachi]This question was posted on [I]AskNACHI.org[/I] by [B]Shayne Duquette[/B] (from Timmins). [/asknachi]I've noticed one corner in my basement is damp. I believe water has found it's way in. How do I determine the main cause of this problem? (weepers, improper drainage, cracks, etc. )
Should or can this problem be looked after from the inside of the home vs. the out?[/quote]
Hire a professional that is trained to look for and recognize potenial sources of moisture intrusion. Erecting and climbing up on ladders can potenially cause more problems if you damage something in the process. Moisture can find it's way anywhere. I have seen water travel up a wall face that has wicked up between layers of stucco. If you do not know what you are looking for, the search can take you a very long time waiting for the right conditions to represent themselves. Professionals have tools like moisture meters, infrared cameras, and past experience and knowledge. It may cost you a few dollars to hire someone to come out, but look at all the time and aggrivation that you can save yourself.
If you have a bad moisture intrusion problem that has been going on for a while, you might want to consider the potenial for mold growth. A professional inspector that is qualified will be able to identify the source of the moisture intrusion and determine if there is mold contributing factors present.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
