AskNACHI.org » DSM Technical Evaluator
Old 12/1/11, 11:14 AM
Pete Koepfgen
Guest
Posts: n/a
Default DSM Technical Evaluator
I’m trying to develop an energy efficiency program on replacing those really old inefficient furnaces that still seem to stick around. Do you know how to identify ~60% AFUE residential furnaces (these should probably be the old gravity/octopus designs) and to differentiate them from the ~70% AFUE (these would probably have conventional blowers for air distribution, a draft hood, but still have a standing pilot)?
1 For the old furnaces (especially gravity, or “octopus” furnaces), are the efficiency ratings on the name plates, still typically readable?
2. If so, do you happen to know if the efficiency ratings are in terms of AFUE, combustion efficiency, or thermal efficiency?
3. If not, the only other way I can think of identifying ~60% efficiency (AFUE) furnaces (and differentiating them from the ~70%-ers), is by checking to see if the furnace is the old gravity type furnace (implies 60% AFUE). The ~70% will typically have draft hoods and a standing pilot light, but will have the conventional blower for air distribution throughout the house. Any comments?
4 Is there an easy way to tell if a furnace is a gravity furnace?
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 12/1/11, 1:50 PM
Nick Gromicko's Avatar
Nick Gromicko Nick Gromicko is online now
Default Re: DSM Technical Evaluator
Mr Koepfgen from Union Gas in Ontario. Please help him if you can.
Find a Home Inspector
Old 12/1/11, 2:02 PM
Michael Larson's Avatar
Yes, gravity furnaces have no mechanical means of distributing the heated air and are identified by large heated air supply piping and often referred to as an Octopus furnace due to their distictive look.
Michael Larson
Hudson, WI
Old 12/1/11, 2:23 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is offline
Send him to ROD COREA www.nrgresources.ca Ph 1-519-559-3923
THE RIGHT TRAK
CIAQP, IAC2
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
