AskNACHI.org » Dura-Pex (NIBCO)Problems
Old 3/13/09, 3:41 PM
bobrucker
Guest
Posts: n/a
Default Dura-Pex (NIBCO)Problems
We have had a problem with Dura-Pex fittings. The sweat x pex adapters are deteriorating and look as if they are rotted after less than 1 year or so. We had a restaurant recently where we had used them to install a scald guard Symmons valve, the crimp ring cracked and blew out flooding the place. When we went to replace the crimp ring the barbed end of the pex fitting snapped off in the Technicians hand like it was rotten. Also the stainless steel crimp rings (p-pex stamped on them) have been cracking and blowing out on us after 3 to 6 months after installation. We no longer use anything but the copper crimp rings.I have several of the old parts at my office.This has cost us alot in damages, free warranty work etc. Im sure it's happening all over the place. Have you seen this problem or have heard about either? Thanks Bob Rucker
Old 3/15/09, 2:22 AM
Brian E. Kelly's Avatar
Default Re: Dura-Pex (NIBCO)Problems
http://www.lawyersandsettlements.com/articles/10631/zurn-pex-brass-fitting-failures.html
Old 9/12/09, 11:46 PM
Minneme
Guest
Posts: n/a
Check out www.uponorlawsuit.com for information about failures of systems with "p pex" fittings and clamps.
Old 9/27/09, 4:43 PM
Unregistered
Guest
Posts: n/a
Bob; Can you call me I have a lot of Dura Pex issues 2146954424
Old 3/18/10, 12:31 PM
Guest
Guest
Posts: n/a
Purchased a home in Nov 2009 with Dura Pex piping. Originally built in 2006.
Have had two instances of pipe bursting on hot water pipe (red clay color) with a longitudinal split of about 1-2" within 8 ft of hot water heater.
PRV okay - was replaced at time of purchase at recommendation of Home Inspection Engr. No cold water expansion tank installed as it was not code at time of build.
Copper pipe from hot water heater extends to length of 18" or slightly more...then dura pex piping throughout home.
Have heard a report from the emergency contacted plumber that patch-fixed the length of pipe that burst with Rehau brand, that dura pex has had bad batches of pipe (quality defects). Plumber advised that with one failure we could expect more later on. Anyone have this experience of knowledge of other complaints? Or, do most failures occur within 10ft of hot water heater.
Fix alternatives - maybe:
(1) Install a cold water expansion tank to relieve the pressure / temp dwell time in the pipe closest to the hot water heater?
(2) Install copper piping to a length of 4ft or more (?).
(3) Replace the dura pex hot water pipe line to all locations in the house where H/W used?
(4) Replace it with what brand Pex piping? Understand Rehau (German) is okay. Any others?
(5) Replace Hot Water heater (50 gal gas heated) with either a tankless gas heater - Noritz or Rinnau and also change out significant portion of dura pex pipe as per item (3)?
TD is SC (td46312@gmail.com)
Old 4/18/10, 8:05 PM
Unregistered
Guest
Posts: n/a
We are having pin hole sized leaks spring from our Dura-pex. We had one on 1/30/10, another one 4/16/10 and one today 4/18/10. Our first two were very near the hot water heater the most recent is farther. They are all in the hot water lines. We have a home warranty and have nearly used the whole budget up. We are looking at having to remove the bath tub to fix the most recent one (not covered by warranty). Our plumber is telling us we need to re- route or reintstall all the plumbing with new pipes.
Our home was built in 2003 in the Lake Wylie, SC area and we purchased November 2009.
TD- have you had any luck with this? I am also curious who your plumber is.... any one else out there with similar problems? Any luck with the builder, Nibco, lawsuits anything? We are looking at thousands of dollars.
Help!
Old 5/7/10, 8:20 AM
Doodle12
Guest
Posts: n/a
Our home is five years old and we had had several problems with the Dura Pex pipes. The first leak that occured blew a hole in our living room wall. We had lots of flood damage. Called Allstate to file a claim. They only paid $1k toward the repairs. The day after Allstate paid us the check, we had another leak and they told us that if we filed another claim with them that our policy would be cancelled. We ended up paying approximatley $8k out of pocket for repairs. This week we actually had two more leaks with the H/W pipes. This time the leak has been going on for about a month and has caused mold to form both in and under the house. We have filed another claim with Allstate for this incident and are praying that they do not cancel our insurance. I have been searching for some type of class action suit or something against the manufacturer of Dura Pex Piping. We cannot afford to replace all the H/W pipes in our house. We do have a pressure release valve installed so that is not the cause of the leaks. Just trying to get the repairs done for this incident and hope that there will be no further problems - yeah wishful thinking!!!
Old 5/19/10, 6:13 PM
Unregistered
Guest
Posts: n/a
lots of problems with Dura-Pex
Old 11/10/10, 3:02 PM
Unregistered
Guest
Posts: n/a
We have had 5 situations of faulty CPI Dura Pex piping in our home.We purchased our home new in 1999.Feb. of this year cost the Ins.Co. 5,000.00 grand,the next 4 pipe splits have cost me 1,100.00 as the Ins.Co. now states that it is a maint.problem.Repipe of house will cost me 5,400.00.Thanks B.O'B.Florence,SC.
Old 12/24/10, 2:43 PM
Unregistered
Guest
Posts: n/a
We have had 6 leaks in NIBCO PEX Pure-Next pipe this year. They have all been on the hot water line. Our pipe is white. five of the leaks have been pinpoint holes in 1/2 in pipe, one was a split in 3/4 in pipe. We have had extensive damage with leak number 5 and will have to replace part of our hardwood floor. This was in a storage closet that then leaked into a bedroom and walk in closet. Three leaks were in a bathroom and we paid of all those drywall repairs. Two leaks were in crawl spaces. Our plumber believes the pipe is defective and has not charged us for the repairs. We have contacted NIBCO and sent the documentation, but have not received a reply--we have been working on this since Jan 17 2010. Our insurance is going to cover leak 5--the most damage. We intend to replace all the pipe in the house which is 5 years old. We would be interested in exploring a class action suit,
Old 2/18/11, 8:28 PM
Unregistered
Guest
Posts: n/a
We have had 6 of the same type leaks over the past few months- we are in Lake Wylie as well Our pipe is labelled 2005 and 2006. Definitely a failure that is causing a lot of $. Would like to talk with you over the phone to discuss what you have learned and possible actions. 80.3-810-92.22 - Stephan
[QUOTE=Unregistered;646934]We are having pin hole sized leaks spring from our Dura-pex. We had one on 1/30/10, another one 4/16/10 and one today 4/18/10. Our first two were very near the hot water heater the most recent is farther. They are all in the hot water lines. We have a home warranty and have nearly used the whole budget up. We are looking at having to remove the bath tub to fix the most recent one (not covered by warranty). Our plumber is telling us we need to re- route or reintstall all the plumbing with new pipes.
Help![/QUOTE]
Old 4/1/11, 10:52 PM
Unregistered
Guest
Posts: n/a
I have to same issues with my home. Dura-pex piping. Pin hole leaks on hot water side caused several thousands in damage. I have been in contact with this company and they have acknowledged the issue. There was a batch of pipes between 2002-2006 that failed some testing but was packaged anyway. They have no idea how many homes were affected. I was told by this company they would cover my damages but when they found out the damages were upwards of 68K they stated I would most likely have to go through my homeowners....BS. I have just contacted my attorney to start a lawsuit against the company. Maybe we should look at a class action suite!! I live in Lake Norman area. If anyone would like to talk please contact me at faulty.dura.pex@gmail.com. There is strength in numbers guys. Lets stick it to these idiots!!!
Thanks,
Old 4/1/11, 10:59 PM
Unregistered
Guest
Posts: n/a
test
Need a home inspection in California? Check out InterNACHI's listing of California certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 6/10/11, 12:12 PM
Unregistered
Guest
Posts: n/a
new home built 2005 started having leaks 2010 have had 9 leaks most looks like pin holes in piping. pex pipe and dura pex also cpi pipe, does anybody no of a lawyer to contact about this problem looks like a nationwide problem according to posts i have read. thanks john perry 251-621-2421
Old 7/4/11, 3:20 PM
chel73
Guest
Posts: n/a
We have had this same problem with the dura-pex splitting. We have had this happen twice since June 4th. Two rooms in our house flooded. Has anyone had luck with starting a lawsuit? I am thinking of contacting the Levin firm in Pensacola to see if they will take our case.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282
