Hi there,
I was wondering if anyone knew the answer to a venting question. I am about to lease an office space. I am a non-profit that serves children in California. I want to put a stove/oven in the kitchen so I can make hot snacks and meals. The kitchen shares a wall with the bathroom. There is a vent in the bathroom that goes to the roof. I was wondering if we could connect the stove vent to the bathroom vent and avoid cutting another hole in the roof. If I can, what kind of ducting do I need to use? I am not sure if this matters, but while the office space is office space now, it was once a restaurant. Thanks so much |
| Find an InterNACHI certified North Dakota Home Inspector (and anywhere else in North America) |
Plumbing vents are for plumbing fixtures ONLY.
You're better off having an exterior vent installed on an outer wall in the kitchen area. |
You are best off to hire someone that has done it , but you may be referring to a range hood.
If the stove is at an outside wall a hole can be punched out . You also may consider a ventless hood that will utilize a charcoal filter that needs to be replaced periodically. |
I would agree with Bob but confirm with your lease agreement about cooking in your space, even though it was a restaurant. No need to install venting when a charcoal filter will work.
Of course we are talking about a single range not a commecial setup which would require a ducted hood with fire suppression. Randy |
